Replacing Drywall On Walls But Want To Keep Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-07-2013, 09:05 PM   #1
Rewards Points: 150
Replacing drywall on walls but want to keep ceiling
I need to remove rotten dry wall around my shower but dont want to tear up the ceiling beside the shower. I dont want to mess with the ceiling because I dont want to have to texture a new ceiling. Can you add new board on the walls without having to damage preexisting ceiling texture?
Ive yet to do any drywall work but I know when 2 pieces come together it has to be taped somehow. So it looks like Id have to pull the old tape off the preexisting ceiling piece which would pull off some of the ceiling texture.
Arsinek is offline   Reply With Quote
Old 02-07-2013, 10:05 PM   #2
Rewards Points: 13,228
A textured ceiling in any room is a bad idea, in a bathroom that's just not right.
Impossible to clean and will be a dust magnet with all that damp air.
To ansewer your real question yes you can cut the tape and just do the wall but then your going to have to remove the old tape on the ceiling and sand it back so you can apply new tape.
Going to be a real pain trying to match the old texture.
Concider removing it.
Old 02-07-2013, 10:11 PM   #3
Rewards Points: 6,652
Do like I did. Tear the walls off, then use a Utility knife to cut the seam between the ceiling and wall. If Gyprock or Plaster with Lathe, then you have to use a Flat Pry bar with a sharpened edge, to break the seam. If you are good, you will not have a large amount of damage, and can easily repair the seam with Hot mud when you go to do the finishing to prep for prime & paint.
As for textured ceilings, scrape that junk off.
Old 02-07-2013, 10:22 PM   #4
Rewards Points: 150
You guys dont have textured ceilings? Pretty much every house down here does. knockdown?
Old 02-07-2013, 10:38 PM   #5
Nope, not in my 70 plus year old Bungalow. Knockdown/Orange Peel/Spray on texture, is to hide the seams, of lazy sloppy mud jobs.
I have Gyprock, and the way I hide the seams, is that I have to shine a light across the ceiling from the wall across it, so that I can see the valley's, and then I just run a knife of Hot mud across to bring everything even.
That is how I did it in my bath refinish, and you cannot tell where the 18 inch by 4 foot sheets are, no matter how hard you try.
Old 02-07-2013, 10:40 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 288
Why remove all the wall to the ceiling? Why not leave 4-6" then butt to it? I've done it that way dozens of times when doing showers and tub enclosures.
What are you installing next? Over what?
Jaz
The Following 2 Users Say Thank You to JazMan For This Useful Post:
oh'mike (02-09-2013), princelake (02-08-2013)
Old 02-08-2013, 07:21 PM   #7
Rewards Points: 150
Jaz
That thought crossed my mind and might work.
Replacing tub and replacing tile tub surround with 3 piece plastic one. At least thats the plan.
Old 02-08-2013, 07:33 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 288
[QUOTE=ArsinekThat thought crossed my mind and might work.[/QUOTE]
Yup, it works every time it's tried.
What? You going to plastic? Why?
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Old 02-08-2013, 07:35 PM   #9
Rewards Points: 512
ya i agress with jazman!
princelake is offline   Reply With Quote
Old 02-08-2013, 08:17 PM   #10
Rewards Points: 150
Jaz
Im under the impression its easier and quicker to put up, never have to regrout.
Old 02-08-2013, 08:40 PM   #11
Rewards Points: 626
come out to the Pacific Northwest all ceilings have orange peel same with walls not having it people think is is crappy drywall job and or the people were cheap and cut corners. it is a regional thing.
Nailbags is offline   Reply With Quote
Old 02-08-2013, 09:28 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 288
Easier? Is that what you want easier?
I've never regrouted any of my tilework. I've only had to recaulk at the tub/tile joint twice in over 42 years. Where is this bathroom?
Jaz
Old 02-09-2013, 12:49 PM   #13
Rewards Points: 150
Jaz
Well Im planning on renting this place out so Im more concerned with just getting it done. I want it to be nice but it doesnt have to be luxurious. My main concerns are durability, cost and time.
Old 02-09-2013, 01:07 PM   #14
Tileguy
JazMan's Avatar
Rewards Points: 288
OK good. As long as it's not one of those $100 things that crack easy it should work for you. Tenants can be rough.
Jaz
Old 02-09-2013, 01:44 PM   #15
DIY staff
Rewards Points: 7,174
Jaz
Especially rough on smooth shiny plastic----
Drywall over open beam ceiling and venting daluu Remodeling 4 11-07-2012 01:54 AM
drywall or sheetmetal ceiling drmax Building & Construction 12 09-21-2012 09:15 AM
Replacing Basement Drop Ceiling w/Drywall sadic1 Remodeling 17 03-18-2012 11:23 AM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Drywall Corner and Ceiling Skim Coat Rbchound Drywall & Plaster 6 04-29-2010 11:59 AM
