#1 |
Replacing drywall, do I need to replace the insulation?
So since the walls are so poorly done I've decided to rip them down and do them over. While I have the walls down to studs should I replace the insulation? It looks okay, I think it says R-13 3.5" which I think is standard so I seem no reason to unless I'm missing something. What else should I do(if anything) now that I have access to the studs?
Also, any suggestions for a knee-wall? I want to drywall that and remove the board look. |
#2 |
Insulation doesn't deteriorate! If moisture gets in there and it becomes moldy, it has to be replaced. Otherwise, its fine!
I think it would be a good idea to use a plastic vapor barrier to give it a better seal and to stop any outside air infiltration. If you do so, the v/b on the insulation should be perforated! |
#3 |
liscenced electrician
Insulation should be fine but you are required to update the electrical
#4 |
What jimmy said. Not sure if it is required, but I don't see an outlet on that wall. There should be at least one, depending on the width.
| Display Modes | |
| Old ceiling replacement | idsp | General Discussion | 12 | 07-25-2009 11:48 AM |
| Replacing Drywall Corner Beads | jodell8964 | Building & Construction | 2 | 03-15-2009 07:31 PM |
| basement insulation and vapour barrier | coolnes | Remodeling | 11 | 02-01-2009 09:56 AM |
| Replacing drywall in shed with osb | elcarlstono | Building & Construction | 1 | 12-27-2007 07:51 PM |
| Help!!! Blow-in insulation bowing drywall | Erebus | Remodeling | 2 | 08-09-2007 08:20 PM |
