-   -   Replacing drywall, do I need to replace the insulation? (http://www.diychatroom.com/f101/replacing-drywall-do-i-need-replace-insulation-46374/)
RyanD 06-10-2009 05:40 PM
1 Attachment(s)
So since the walls are so poorly done I've decided to rip them down and do them over. While I have the walls down to studs should I replace the insulation? It looks okay, I think it says R-13 3.5" which I think is standard so I seem no reason to unless I'm missing something. What else should I do(if anything) now that I have access to the studs?
Also, any suggestions for a knee-wall? I want to drywall that and remove the board look.
Wildie 06-10-2009 07:27 PM
Insulation doesn't deteriorate! If moisture gets in there and it becomes moldy, it has to be replaced. Otherwise, its fine!
I think it would be a good idea to use a plastic vapor barrier to give it a better seal and to stop any outside air infiltration.
If you do so, the v/b on the insulation should be perforated!
jimmy21 06-11-2009 12:27 AM
39 Attachment(s)
Insulation should be fine but you are required to update the electrical
Just Bill 06-11-2009 06:22 AM
What jimmy said. Not sure if it is required, but I don't see an outlet on that wall. There should be at least one, depending on the width.
RyanD 06-11-2009 08:46 AM
Even in the basement? Is this code?
