Replacing Drywall Ceiling Only, Not Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-12-2009, 11:56 AM   #1
shan1616
Replacing drywall ceiling only, not walls
I've noticed some cracking and imperfections in my popcorn ceilings and would like to replace them ourselves. I'm wondering if it is possible to replace only the ceilings and not the walls. I work in a library so I have access to many books on the subject but they all give instructions from unfinished starting points.
How would I get the old ceiling down, and put up the new one, while leaving the walls untouched?
shan1616 is offline   Reply With Quote
Old 11-12-2009, 12:03 PM   #2
Just take a utility knife and score the seam between the walls and the ceiling. Make sure you cut deep enough to cut the tape. After the ceiling is down, take the knife and clean up the top edge of the wall and scrape off any of the loose joint compound. When you replace the ceiling try to get the drywall to slide into the void created.
jerryh3 is offline   Reply With Quote
Old 11-12-2009, 12:30 PM   #3
Rewards Points: 1,010
Before you do anything, get the popcorn ceiling tested for asbestos
Anti-wingnut is offline   Reply With Quote
Old 11-12-2009, 03:08 PM   #4
if the popcorn is neg for asbestos scrape it off and either refinish or laminate new drywall to old 1/4 to 3/8 is plenty thick
Old 11-12-2009, 06:15 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,.... I agree,.. Especially if the original ceiling is holding up the attic insulation....
Old 11-13-2009, 03:58 PM   #6
Drywall contractor
Rewards Points: 1,070
Another layer is the best option, especially if there's blown in insulation above......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-14-2009, 08:03 AM   #7
shan1616
Thanks to everyone who replied. All good ideas!
Old 11-14-2009, 08:48 AM   #8
Another vote for laminating old onto new, but thicker is better; 1/2 or 5/8. Thinner GWB will inherit and telegraph any existing bows or waves. Thicker rock can (may) bridge and push imperfections away
Old 11-15-2009, 01:45 PM   #9
shan1616
But, to put another layer of drywall, do I really have to scrape off all the texture, or can I just put the drywall over top?
Old 11-15-2009, 02:27 PM   #10
Drywall contractor
You can go right over the texture. 1/2" would do a better job also. As stated above, it will do a better job of hiding/spanning imperfections that don't show as readily with texture. 5/8" is better than 1/2", but overkill I think unless you have particularly wavy framing. A lot harder to deal with too. 1/4" or 3/8" are acceptable. I use 1/4" over plaster where I have to butt to the trim and still want a reveal. I normally use 1/2" for ceiling overlay even if the framing is pretty straight, just because it's cheaper....
Old 11-15-2009, 03:15 PM   #11
My 2 cents: DIY drywall sanding is not fun and ceiling drywall sanding is even worse so make sure you get a good respirator/goggles. Great advice has been provided but consider ceiling tiles or wood strips options before tearing the original drywall down.
aggreX is offline   Reply With Quote
Removing Ceiling Drywall maenos Drywall & Plaster 14 03-08-2011 09:48 AM
Replacing plaster with drywall secutanudu Drywall & Plaster 14 11-15-2009 11:44 AM
Hanging Drywall to a finished Ceiling, Seam Questions? Worker-B Drywall & Plaster 5 08-24-2009 09:40 AM
Replacing Drywall Corner Beads jodell8964 Building & Construction 2 03-15-2009 06:31 PM
Using drywall for Drop Ceiling rickkeeter Drywall & Plaster 8 02-13-2009 07:52 AM
