Replacing Damp Drywall / Plaster In Shower - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-25-2010, 02:25 AM   #1
Replacing damp drywall / plaster in shower
Hi all. I'm new here and not good at fixing anything. I noticed an area in the shower where the plaster was damp and giving way. I removed the offending plaster & replaced it. I sanded down rougher areas the next day.
Do I apply some sort of primer before re-painting? This doesn't seem difficult, but I want to get it right the first time. Any suggestions are most welcome!
Thanks.
Elcontador is offline   Reply With Quote
Old 02-25-2010, 03:27 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
An oil based primer would be best
Old 02-25-2010, 05:03 AM   #3
Too Short? Cut it Again!
Your post suggested damp drywall and plaster? No matter if you have plaster over drywall I guess but if you do, did you also cut out and repair the underlying damp drywall? And source whatever is causing it to become damp? If not, your problem will return.
Replacing plaster with drywall secutanudu Drywall & Plaster 14 11-15-2009 11:44 AM
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
Replacing damaged shower wall tiles kevind Flooring 4 11-20-2006 12:18 PM
Replacing damaged shower wall tiles kevind Remodeling 3 11-15-2006 10:36 PM
Joining drywall and plaster pete1972 General DIY Discussions 5 10-28-2006 05:08 PM
