Repairs After Removing Wallpaper - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 03:04 PM   #1
Rewards Points: 254
Repairs after removing wallpaper
We decided to remove the wall paper and paint the walls instead. Purple wallpaper looks horrible btw. We figured the past owner did a half azzed job and we were right. We removed the wallpaper to find tore paper on the sheetrock all around. Some places were down to the white. He moved the light switch and covered the hole with a cut beer can with 4 screws and papered over that. SO major work is needed and wanted to make sure I have the steps down. I planned to skim the walls with with joint compound, patch the holes and tape and bed a few areas. Sand everything smooth and apply texture to the walls. Prime and then paint. Am I missing anything?
pwgsx is offline   Reply With Quote
Old 03-26-2012, 05:05 PM   #2
Too Short? Cut it Again!
You should apply Gardz before you attempt your skim coat and associated repairs.
Old 03-26-2012, 05:27 PM   #3
Rewards Points: 254
So seal with Gardz, then skim coat, sand, texture , prime and paint?
Old 03-27-2012, 04:44 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Gardz, skim, sand,CLEAN,Gardz,texture,Gardz,paint
The Following User Says Thank You to chrisn For This Useful Post:
user1007 (04-01-2012)
Old 04-01-2012, 01:36 PM   #5
Drywall contractor
Rewards Points: 1,070
I generally sand first to get as much loose paper off as possible, then prime and follow directions above....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-06-2012, 10:28 AM   #6
Rewards Points: 254
thanks for the replies, however the house caught fire on sunday. It has to be gutted and rebuilt........
Old 04-06-2012, 06:18 PM   #7
chrisn's Avatar
Rewards Points: 228
Wow! Didn't see THAT coming.
Old 04-06-2012, 06:39 PM   #8
Rewards Points: 254
Us either......
Skim Coating wall After removing wallpaper stevenson66 Painting 6 11-08-2010 08:35 PM
Removing wallpaper redheadps Drywall & Plaster 5 07-20-2010 11:24 AM
Removing Wallpaper Paste Bliss7777 Painting 13 08-07-2009 05:46 AM
Removing Wallpaper fcamargo6thave Painting 17 04-27-2009 03:59 AM
Removing wallpaper and repairing plaster walls Boroco General DIY Discussions 3 03-27-2009 02:27 PM
