Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-04-2013, 11:05 AM   #1
Repairing Walls after a Tile Removal
I removed a bunch of tile that pretty much killed my bathroom walls. I was going to throw some sheetrock joint compound on it but I don't know if that will do the trick.
sedona03 is offline   Reply With Quote
Old 02-04-2013, 11:57 AM   #2
Super Moderator
It will be less work to simply replace that dry wall--
If you wish to repair it----prime well with Guards--
remove and loose paper and skim coat with Multi Purpose drywall compound---It contains glue and will bond best to the rough paper---
if the paper continues to bubble up from the wet compound--stop--cut out the bubbled paper---soak with more guards--and go at it again.
Thin coats----I suggest you use light weight compound for the top coat---it's easier to sand than multi-purpose
ToolSeeker (02-04-2013)
Old 02-04-2013, 01:57 PM   #3
What are guards?
Old 02-04-2013, 03:25 PM   #4
Super Moderator
Sorry, I wasn't clear----
Guards is a liquid primer---it's clear and dries fast and is the ideal primer for ripped up drywall---
Old 02-04-2013, 03:45 PM   #5
Super Moderator
Wallpaper Removal Gone Awry. Advice To Get Back On Track? - Painting - DIY Chatroom - DIY Home Improvement Forum
i miss spelled that primer--'Gardz' is the right spelling (I think)
Old 02-04-2013, 05:36 PM   #6
paper hanger and painter
chrisn's Avatar
here it is
Rain seepage stain removal and sealing on bare block walls Peipei9 Concrete, Stone & Masonry 2 03-29-2012 06:37 PM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
ceramic tile walls ponch37300 Remodeling 7 02-19-2009 06:40 PM
12x12 tile on small bathroom walls???? trueform General Discussion 4 06-24-2008 12:34 AM
