Repairing Walls after a Tile Removal
I removed a bunch of tile that pretty much killed my bathroom walls. I was going to throw some sheetrock joint compound on it but I don't know if that will do the trick.
http://i.imgur.com/bZjWPn1.jpg |
It will be less work to simply replace that dry wall--
If you wish to repair it----prime well with Guards-- remove and loose paper and skim coat with Multi Purpose drywall compound---It contains glue and will bond best to the rough paper--- if the paper continues to bubble up from the wet compound--stop--cut out the bubbled paper---soak with more guards--and go at it again. Thin coats----I suggest you use light weight compound for the top coat---it's easier to sand than multi-purpose |
What are guards?
Sorry, I wasn't clear----
Guards is a liquid primer---it's clear and dries fast and is the ideal primer for ripped up drywall--- |
Wallpaper Removal Gone Awry. Advice To Get Back On Track? - Painting - DIY Chatroom - DIY Home Improvement Forum
i miss spelled that primer--'Gardz' is the right spelling (I think) |
1 Attachment(s)
here it is
| All times are GMT -4. The time now is 07:18 AM. |
