Repairing Vinyl Coated Sheetrock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 12:39 PM   #1
Repairing vinyl coated sheetrock
Hey guys,
I was going to repaint my bathroom and while pulling off a light fixture from the wall, I pulled a huge chunk of the vinyl from the vinyl coated sheetrock (I assume it's vinyl coated since it's plastic like). What I have now is white exposed gypsum. is there a way to reseal this effectively without replacing the sheet?
sherab is offline   Reply With Quote
Old 11-04-2012, 12:46 PM   #2
Rewards Points: 13,960
Is this in a mobil home?
About all you can do is use some wall paper paste and trying stick it back up.
Not going to be pretty.
Old 11-04-2012, 02:16 PM   #3
Thanks joecaption for your quick response. It's a regular apartment. I think the way to go is probably to use joint compound, sand it down and then seal it with a primer. Anyone know of a pitfall to this approach?
Tags
bathroom , vinyl sheetrock
vinyl squares over vinyl? brewer362 Flooring 2 03-03-2012 11:24 PM
Vinyl floor tiles on vinyl floor Project423 Flooring 2 02-27-2012 01:04 PM
Joint compound over vinyl sheetrock Fergus Drywall & Plaster 5 02-04-2010 11:57 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
