Repairing Trim Around Closet? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 02:05 PM   #1
Repairing trim around closet?
Hi Everyone - I'm looking for tips on how to repair some chipped trim around my closet. I'm thinking wood filler, putty knife, sand paper, and paint? Any recommendations on wood filler that I can buy at Lowe's?
cksv is offline   Reply With Quote
Old 11-05-2011, 02:46 PM   #2
Ironlight's Avatar
"Plastic Wood" brand is the standard for those sorts of repairs and should work fine on that. When you apply it and shape it, try and get it as close to flat and level and the shape of the adjoining wood as possible since it is a bit of a bear to sand. Sand paper wrapped around a wood block will help in that process.
Ironlight is offline   Reply With Quote
Old 11-05-2011, 04:02 PM   #3
A Little Of Everything
Rewards Points: 1,364
Plastic Wood will work, or Durham's Rock Hard Putty. Both will be similar in how you use them, and the results. I prefer Durham's because it's pretty cheap.
Good luck!
DrHicks is offline   Reply With Quote
repairing damaged cedar trim Master Brian Remodeling 3 09-10-2010 01:30 AM
Metal trim around closet openings rovers1973 Drywall & Plaster 8 08-04-2010 11:39 AM
Sliding Closet Doors & Base Trim HangGlide Carpentry 4 03-26-2010 11:09 AM
closet stud wall, doors, and trim theboss Carpentry 1 02-16-2009 11:23 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
