Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 09-30-2012, 09:52 PM   #1
Repairing Torn Drywall
I was removing tiles from the side of the walls around my sink counter tops and on one side the drywall was completely torn off. I'm not sure how I should go about repairing it, since the entire side is torn up, but the hole is only in the center of the drywall.
oceanlife is offline   Reply With Quote
Old 10-01-2012, 06:27 AM   #2
sdsester's Avatar
That is going to require that you cut a patch section. Being careful not to nick electrical, cut out the damaged section. You can use the framing as a guide for the drywall saw on the sides. You will need to cut some scrap 2x4 blocks and attach them to existing framing so you have something to screw the drywall patch to. Cut it the size of the opening. Screw it in place, mud and tape.
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
ToolSeeker (10-01-2012)
Old 10-01-2012, 08:41 AM   #3
That texture is going to have to be sanded off the wall at least 2" up from your new patch so you can apply the tape.
Old 10-01-2012, 11:44 AM   #4
Great, thanks for the tips! So I place the mud over the entire section, tape and then reapply the mud?
Old 10-01-2012, 11:50 AM   #5
What are the main reasons for having to do this? Does it make it easier to blend the tape into the wall?
Old 10-01-2012, 04:35 PM   #6
sdsester's Avatar
No, you cannot repair this with mud or anything else. You need to cut and fit a new patch. You cannot expect the tape to hold on textured painted surface which is why Joe suggested you have to sand it down.
Old 10-02-2012, 12:49 AM   #7
Moderator
You could buy a "patch kit" that has most everything you need: http://www.usg.com/rc/installation-a...s-en-J1802.pdf
How to match the texture, if no backsplash: http://www.youtube.com/watch?v=AAxNL...feature=relmfu
Gary
P.S. Hope the outlet is GFCI protected...
Clothes taking longer to dry?
Old 10-02-2012, 08:53 AM   #8
Also to rematch the texture you can go to the big box or most hardware stores and get a can of orange peel texture with the adjustable nozzle, practice on some scrap blend it in PRIME and paint. Good luck
Old 10-02-2012, 08:30 PM   #9
I patched the hole with new drywall and sanded around the outside edges. I'm planing on applying bulls eye 123 primer on the exposed paper and gypsum, followed by a coat of hot mud. I'm unsure on whether I should use the hot mud for my second coat or use an all purpose joint compound, since my walls are textured.
Old 10-02-2012, 08:44 PM   #10
You are a little bit backwards on one point don't prime until you are done with the mud, and you know you have to put tape over the joints right? and for 2nd coat you can use hot mud or all purpose. All purpose is a lot easier to sand but takes longer to dry.
Old 10-02-2012, 09:03 PM   #11
Yeah, I'm doing the taping next. I was told to prime the exposed paper and gypsum with 123 in place of gardz (I haven't been able to track it down). I assume this isn't necessary then, so I should just tape and apply the hot mud?
Old 10-03-2012, 07:35 AM   #12
Correct do all your mud work then prime. And the 123 is a good primer.
repairing drywall cracks in ceiling justin 418 Drywall & Plaster 3 12-28-2009 06:18 PM
Drywall - fixing patches from torn off glue DK75 Drywall & Plaster 4 12-07-2009 08:16 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Repairing cracked drywall seams pjm Drywall & Plaster 3 03-08-2009 01:34 PM
Repairing a small hole in drywall jweiner Drywall & Plaster 9 01-28-2009 09:53 PM
