Repairing Plaster Ceiling 3'x5' Hole - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 07:14 PM   #1
Repairing plaster ceiling 3'x5' hole
Hello. I am trying to find some information about repairing a plaster ceiling in my living room. We have had an on-going moisture problem around the chimney, and the plaster ceiling finally started to give way right around where the leak is. I have torn down the bubbled and broken plaster that was in danger of falling, and will be cutting out a 3'x5' square of plaster in order to repair it. However, the plaster is attached to a type of fiberboard as opposed to a wood lathe, and this stuff seems extremely fragile as well as prone to absorbing water. I am going to have to put some type of material down underneath the replacement drywall, and I am hoping I can get some suggestions as to what to use to repair this. I won't be completing this repair until we have definitely fixed the leaking problem we have been having, I am just looking for some insight. Thank you
Repairing plaster ceiling 3'x5' hole-ceiling.jpg   Repairing plaster ceiling 3'x5' hole-ceiling2.jpg
stock2mal is offline   Reply With Quote
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
Kraft paper on ceiling joists for plaster jefsboys Building & Construction 0 09-30-2010 01:08 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Repairing ceiling Arnold General DIY Discussions 8 09-12-2008 09:13 PM
Repairing Ceiling Crack Seam bakerhouse Building & Construction 6 05-05-2008 03:56 PM
