Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-26-2012, 04:29 PM   #16
Moderator
repairing long crack along metal corner bead
That should work with the paper tape hiding the crack. Some pros do this- to metal corner bead- tape over just the outside ends, not the middle of the c.b.; https://docs.google.com/viewer?a=v&q..._KKuN-dhkJrzwA
Older metal c.b.'s show cracks, often from the wood framing expanding/contracting with the seasons or HVAC changes because they are fastened through to that framing rather than just drywall, as are paper-faced metal beads, clinched-on and "speed bead"; http://literature.usg.com/pdf/J1445.pdf
Gary
Clothes taking longer to dry?
Corner bead on a recessed ceiling jackrobat Drywall & Plaster 5 03-25-2011 10:42 AM
Corner Bead Coming Loose bhumeny Drywall & Plaster 4 05-03-2010 09:33 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Corner Bead....Metal or Plastic? yummy mummy Building & Construction 2 01-23-2008 06:11 PM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 04:25 PM
