-   -   repairing long crack along metal corner bead (http://www.diychatroom.com/f101/repairing-long-crack-along-metal-corner-bead-148083/)
joetab24 06-24-2012 12:22 PM
I was just reading a previous thread on this site about a similar kind of drywall crack, along the corner bead. One answer was that the metal bead had moved/dislodged and needed to be nailed/screwed back in to place. I tried to put a a few drywall screws into the corner, to no avail. As I was doing this, I realized I had no idea where the holes in the corner bead were.
Should I remove the existing joint compound (sanding? break it up?) to find out where to put the screws?
http://i779.photobucket.com/albums/y...4/IMAG0742.jpg
The hairline crack pretty much goes right to the ceiling.
http://i779.photobucket.com/albums/y...4/IMAG0743.jpg
And if you're feeling generous, what would you do with this section (see my last post)?
Thanks! :)
JetSwet 06-24-2012 06:07 PM
I think you could have just gotten away with just spackeling that. Sheetrock screws only no nails will hold the corner bead, they probably didn't put Enough in when installed.
princelake 06-24-2012 08:11 PM
i'd just put the screw as close to the edge as possible, no need to look for the actual holes. check with a drywall knife to make sure it all can be coat(no screws sitting out so it will bump) then mud it, sand, prime paint.
CopperClad 06-24-2012 08:54 PM
I don't know what other thread you are referring to so I will just give you my input. A lot of drywall finishers didn't tape the corner bead to the drywall that is why the crack is there. Even if you joint compound over, it will crack again. And like whomever said, you don't need to screw in the holes supplied, just makes it a little easier for new installation. Tape it, float it, no more crack.
JetSwet 06-24-2012 10:03 PM
Nah, to tape over corner bead it will shatter once it gets knocked into... servers no purpose it won't cover the crack, it will just cover the corner bead.
It's common on none load barring walls.
CopperClad 06-24-2012 10:08 PM
So your saying, if he screws the corner bead , and then tapes and muds the crack, if someone bumps into the corner it will shatter.. But you just wanted him to touch it up with some mud.. If someone bumps in the corner then it won't shatter?
JetSwet 06-24-2012 10:15 PM
The corner bead is there for a reason, don't mess with it by putting tape over it folded outwards with mud on it think about it once it gets hit, not only that but your suppose to leave if any like no mud on the actual bead itself and that gets panted.
CopperClad 06-24-2012 10:17 PM
It sounds like your a drywall finisher JetSwet, yes?
JetSwet 06-24-2012 10:22 PM
It's not my profession but have hung taped and finished enough drywall to kill a small animal.
CopperClad 06-24-2012 10:24 PM
And on a new wall do you not tape the corner bead to the sheetrock?
joetab24 06-24-2012 10:35 PM
"I don't know what other thread you are referring to so I will just give you my input."
I linked to the other thread in my original post above. I was also looking for some help with the area near the radiator. You'll see that if you click on the link above.
Thanks for all of your help here!
JetSwet 06-24-2012 10:46 PM
No you use sheet rock screws to attach the corner bead on the sheet rock then mud it 3 or 4 coats.
CopperClad 06-24-2012 10:53 PM
Ok. Well the reason that crack is there , is because it wasn't taped to the sheetrock. If you don't tape the corner bead to the sheetrock you should start ! Many homes that you walk into has that crack you see.. and its not because lack of screws/nails, although nails in the old days did make it worse. Tape it! No crack! Good luck !
JetSwet 06-24-2012 11:04 PM
All on preference to tape the corner bead, lack of screws yes not enough layers of mud, none load barring walls movement therefor separation crack.
I hear what your say good point thanks :)
joetab24 06-25-2012 10:56 PM
I put tape on a section and added some joint compound. It appears this will work.
