Repairing Drywall Tape - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 12:34 PM   #1
Repairing drywall tape
Guess I can't complain, but after 30+ years the tape is peeling away from the sheetrock in several places around the house, especially in the corners.
Any tips on removing the old stuff with minimum damage?
Once I get the loose stuff off, should I tape & float again or is there a better solution? My son-in-law tells me that lost of new construction is using flexible filler (caulk) in corners instead.
bcouch is offline   Reply With Quote
Old 09-07-2009, 03:57 PM   #2
Rewards Points: 5,336
Never saw the flexible caulk route.
Easy just to cut the tape and remove the loose parts. Check to see if moisture is doing this. Drywall tape doesn't generally just fail after that length of time without a precipitating cause.
If there's no issue, just tape as usual.
Ron
Old 09-08-2009, 04:19 PM   #3
Drywall contractor
Rewards Points: 1,070
Tear out the loose stuff, re-tape and finish. Caulk is ok for short term fix of minor cracks in corners, not for an actual finished product. Corners often crack out and tape "pops" due to lumber movement during heating and cooling seasons....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Repairing cracked drywall seams pjm Drywall & Plaster 3 03-08-2009 01:34 PM
Repairing a small hole in drywall jweiner Drywall & Plaster 9 01-28-2009 09:53 PM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 10:27 PM
How to use non-adhesive drywall tape? tripower Building & Construction 1 05-28-2007 10:29 AM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 12:53 PM
