Repairing A Drywall Repair Ive Already Painted Over - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 11:12 PM   #1
repairing a drywall repair ive already painted over
I recently repaired a strip of drywall tape from ceiling to floor. I thot i sanded it thoroughly, but little areas show small holes and a cpl lines. from a distance it looks fine, but wud like to fix the problem. any suggestions
batboy113 is offline   Reply With Quote
Old 12-19-2011, 06:55 AM   #2
Rewards Points: 1,502
Paint scraper and then sand/compund as needed. You could wet the wall to make the scraping easier.
You could just sand through the paint, but that's a chore.
mikegp is online now   Reply With Quote
Old 12-19-2011, 09:51 AM   #3
Rewards Points: 14,312
If there's no high areas and just air holes a very thin layer of spackle will fill them. Sand again with a fine sanding spong in a ciruler motion, then prime and paint.
Using tape on a ceiling drywall repair janralix Drywall & Plaster 8 09-22-2011 10:07 AM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
Drywall repair and matching texture question RickDel Drywall & Plaster 4 08-22-2010 10:52 AM
Refinish painted drywall broadbear General DIY Discussions 1 03-29-2009 12:48 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
