Repairing Drywall For Knee Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 08:27 AM   #1
Repairing drywall for knee wall
In a book on drywall, I read that there is a product on the market intended for use as drywall tape for the obtuse angle found in knee walls. It is a drywall tape that has a vinyl bead that allows for some expansion and contraction. I think it is also adhesive. Anyone use such a product with success? Is it available at your average DIY store? The book did not give a brand name for this product or any other help in the "source" section. Also, have been told that "vinyl" drywall compound is useful in this application. Any advice on that? Unfortunately, my last attempt at repairing this joint took forever, looked good for six months, and now the cracks have all returned with a vengeance. (I used paper drywall tape and regular joint compound.) Totally demoralizing. I don't want to make that mistake again.
Felmo is offline   Reply With Quote
Old 12-21-2011, 09:04 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Knee walls have an obtuse angle?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-21-2011, 11:46 AM   #3
off-angle corner
Maybe I am not using the correct terminology. Let me try again: Where the sloped ceiling meets the flat wall, it creates a corner much greater than 90 degrees. It is an off-angle corner. Any suggestions?
Old 12-21-2011, 12:17 PM   #4
Disabled wood vet
titanoman's Avatar
I don't know why its cracking. Paper tape should have been fine. The only reason for plastic or metal is to get a nice, straight line.
Old 12-21-2011, 08:56 PM   #5
retired union carpenter
Send a message via Yahoo to coupe
I agree with Titanmen, paper tape should've worked? however, I did find this
http://www.google.com/url?sa=t&rct=j..._G0qQyxrr5TQoA
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Drywall Bulge after installed TV wall mount tstecko Drywall & Plaster 15 03-23-2010 08:35 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
