Repairing Drywall Cracks In Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-24-2009, 09:23 AM   #1
Post
repairing drywall cracks in ceiling
i have afew cracks running the length of my ceiling and im wondering the best way to go about repairing them. some say tape others say just fill in the cracks so im curious to see what advice is out there, any advice would be helpful,thanks
justin 418 is offline   Reply With Quote
Old 12-24-2009, 10:05 AM   #2
you will want to use tape, paper tape for its strength. Then finish as usual (ie 3 coats or so).
bkeech is offline   Reply With Quote
Old 12-24-2009, 12:24 PM   #3
Remodeling Contractor
open the crack with a v-groove pattern to allow some compound to seal the crack. Use paper tape and compound with three coats to feather it out. Use Durobond 90 for the first two coats. This dries faster and much harder. The premixed compound can be used for the last coat.
Old 12-28-2009, 05:18 PM   #4
Drywall contractor
Rewards Points: 1,070
If they run the length of the ceiling, it sounds like the tapered edge joints that are cracking. Are the cracks 4' apart?? Makes me wonder if there's a lot of lumber movement occurring with seasonal (heat/cool) changes? Could be the framing is over spanned. Just "hairline" cracks? How old is the house? Your best bet would be to tear out back down to the drywall, tape and all. The tape itself has likely cracked due to some sort of movement. You can tape over the cracks and finish, but you're just "piling" more mud on and will most likely end up with the joints bulged (unless you're a fairly accomplished finisher). Re-tape with paper tape and setting type compound (more strenght and less shrinkage), two coats of compound (ready mix is fine), sand and paint.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Hanging Drywall to a finished Ceiling, Seam Questions? Worker-B Drywall & Plaster 5 08-24-2009 09:40 AM
drywall for the ceiling genner Drywall & Plaster 8 01-11-2009 09:29 AM
Take down drywall on bedroom ceiling to add height clkad Carpentry 10 03-23-2008 12:04 PM
Repairing 2x4 foot drywall in ceiling LukeCT Remodeling 2 03-21-2008 11:55 PM
Hanging Drywall over ceiling tiles bjorgens Remodeling 4 12-19-2007 12:59 PM
