Repairing Drywall Cracks - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-29-2010, 01:20 PM   #1
Rewards Points: 518
Repairing drywall cracks
I remember awhile back someone explained a method of repairing hairline drywall cracks with caulking. If the joint is solid but cracked from settling, I believe the trick was to "V" out the crack, fill in with flexible acrylic caulking, then mud over top of that. Is anyone familiar with this?
n0c7 is offline   Reply With Quote
Old 01-29-2010, 03:45 PM   #2
you are correst sir. You need to did out the crack so when you install the material there is enough space there to get a good amount of material in there. Problem is if you mud over the caulking, they will expand and contract at different rates and you will probably show cracks soon enough. I would dig it out and just use some dura bond and a finish.
wnabcptrNH is offline   Reply With Quote
New Home, cracks in drywall. Whats the cause? fix? hurricane87 Drywall & Plaster 27 01-18-2015 11:54 AM
Drywall Cracks in High-Rise Condo ghanson Drywall & Plaster 1 12-29-2009 02:02 PM
repairing drywall cracks in ceiling justin 418 Drywall & Plaster 3 12-28-2009 05:18 PM
curious cracks in drywall, plus door sag bleedpurple Drywall & Plaster 13 07-04-2009 03:01 PM
drywall cracks? rickevin29 Painting 4 11-05-2006 10:50 AM
