Repairing Drywall Around Shower Stall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 03:12 PM   #1
repairing drywall around shower stall
Hello,
While doing a small remodel on the bathroom, I realized there was paint peeling near the top of the one-piece fiberglass tub/shower unit. I looked at it and discovered that when it was installed, they put drywall to the edge of the flange, but then did not fill the void (about 1") over the flange with anything- they simply put drywall tape from the edge of the drywall to the wall of the stall leaving the area over the flange filled with nothing but air. Now the tape is peeling, and the drywall looks ok, but I want to fix it right to prevent further damage.
From researching this, it seems like I can cut the tape away, fill in the void, then sand and paint. Is this correct? Also what is a good drywall mud to use for this application? I have not worked with drywall mud/tape at all so I need something that is idiot-proof. I just want to prevent further damage.
Thanks for the help,
Matt
gogreenwave is offline   Reply With Quote
Old 02-14-2013, 04:37 PM   #2
Rewards Points: 13,274
The drywall was suppost to be within 1/4" of the top of the enclosher not 1".
Old 02-14-2013, 05:57 PM   #3
Rewards Points: 5,974
Far from idiot proof but the best mud would be dura rock after it dries moisture won't affect it. The down side is it's hard to work with, it's not sand able so has to be put on smooth. Maybe someone else has a better solution.
Old 02-18-2013, 11:18 PM   #4
Cut the paper away and use a fast set mud to fill it in, sand when dry.
waynestractor is offline   Reply With Quote
Repairing drywall for knee wall Felmo Drywall & Plaster 4 12-21-2011 08:56 PM
framing a shower stall n2learning Building & Construction 10 04-07-2011 08:34 AM
Repairing missing grout in shower stall CLM Tiling, ceramics, marble 14 10-03-2010 11:08 PM
Advice about framing for a shower stall Tooncie Building & Construction 1 08-27-2010 09:54 PM
2 Drywall boards behind shower tiles? Confused1 Drywall & Plaster 15 02-15-2010 10:06 AM
