Repairing Corner Cracks - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 06:19 PM   #1
Repairing corner cracks
I've got a couple long running ( over 3ft ) cracks in some corners that I'm working on fixing up before I paint and was wondering if scraping down to the drywall and re-taping/mudding is generally the best option?
If it is - are there any tricks to scraping compound off of the wall without nicking the very top layer of paper? I got the job done on the first crack and got better as I went along, but I still ended up with quite a few small nicks in the paper.
danzik17 is offline   Reply With Quote
Old 11-22-2011, 11:05 AM   #2
Rewards Points: 1,442
Nicking the paper isn't that big of a deal in my opinion. Especially if it is within the area you will be mudding anyway.
I wonder if wetting the compound would help get it off easily. Also, try to deal with the cause of the cracking before repairing. Was the corner framed and connected correctly?
mikegp is offline   Reply With Quote
Old 11-22-2011, 06:28 PM   #3
Good to know about the paper, I was definitely a little concerned about that since I wasn't sure.
I don't know enough about corner framing to be able to tell you if it was correct, but I did feel like there was too much of a gap where the two boards joined. Maybe a centimeter or two ( it's mudded over now so I can't check ), but that's something I'll be checking on the second crack ( the worse one ) when I start on it if that's important. I also zipped a bunch of new screws into the boards to make sure they can't move at all.
It also looked like whoever put the drywall up originally tried to (poorly) use mesh tape in the corner - swapping that to paper will help a lot from what I've read.
Old 11-22-2011, 08:15 PM   #4
Rewards Points: 150
I've had good luck with the metal paper faced corner bead from USG.
stradt03 is offline   Reply With Quote
Old 11-22-2011, 08:27 PM   #5
After reading your response and re-reading mikegp's, I realized I never said these were interior corners, not exterior ones - that's my fault.
Old 11-22-2011, 08:51 PM   #6
I assumed you meant interior. I've experienced them as well. I put 15 screws in a corner once to prevent it from reappearing. It actually worked. Some people don't believe in screwing corners and would rather let them float.
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 01:45 PM
Repairing a concrete foundation corner. Timlo Building & Construction 4 10-11-2011 11:40 PM
Repairing cracks in concrete utility sink machouinard General DIY Discussions 3 08-20-2011 10:48 PM
Repairing drywall cracks n0c7 Drywall & Plaster 1 01-29-2010 04:45 PM
repairing drywall cracks in ceiling justin 418 Drywall & Plaster 3 12-28-2009 06:18 PM
