#1 |
Repairing Bad Spackling Job
Hi!
I have a wall that someone did a lousy drywall job on. So, apparently, someone tried to hide it with a lously spackling job. They spackled over the wall in lots of places to try to make it look better, I guess, but it probably made it look even worse. Now there is lumpy spackle all over, which has been painted over. Any suggestions for the best solution? Should I scrape and sand, and then spackle any small holes, and then just finish with a skim-coat of compound for the whole wall to make it all smooth and even? Thanks! |
#2 |
That sounds like exactly what I would do.
#3 |
Thanks. I've never really skim-coated before, and I see that there are different kinds of compounds. I guess different types for 1st coat, 2nd coat, etc? Can you recommend which I need for the job I described?
#4 | |
Repairing Bad Spackling JobQuote:
#5 |
Drywall contractor
I'd recommend regular ready mix if you're going to "glaze coat" the entire surface. The lightweight is too "soft" and will scratch/ding more easily. Some swear by it, but I don't use or recommend it...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops. |
#6 | |
Learning by Doing
![]() I'm only a DIYer, but I've now done a ton of skim coating in my house. The ready mix does NOT dry hard enough for wide application, especially in high traffic areas you'll see dents/dings/scratches. It also seems more likely to develop micro-fine air bubbles that leave a porous feeling/looking surface. The stuff in the bag isn't that difficult to use and gets a noticeably better result. If you're doing a large area, it's cheaper too!
If I could only remember to THINK about what I was doing before I did it. |
#7 |
Drywall contractor
Agreed the setting type compound is the "hardest" and I personally would use it for the first coat, but I'd use ready mix for the final "tight" skim. Ready mix is often the easiest for the DIY'er and regular is better than lightweight.....
#8 |
Instead of skim coating, I use FirstCoat and have had good results.
#9 |
Facilities Maintenance
1st Scrape it off
2nd. Sand everything down. 3rd, redo it. |
#10 |
sheetrock 45 baby.. or if your quick durabond 5 ! have fun gettin muddy.. and when you float use the body of the blade not just the edge.. kinda rock it..
| Display Modes | |
| Repairing pits and rough spots | dcormann | Drywall & Plaster | 2 | 05-03-2011 11:11 PM |
| repairing electrical outlets in old Plaster lath walls | jjchips | Carpentry | 3 | 09-04-2010 11:20 PM |
| Grass Trimmer Worth Repairing??? | jlaustin | Tools | 3 | 08-06-2010 08:01 PM |
| Repairing wood siding next to a door frame... | Beth777 | General Discussion | 7 | 07-22-2008 09:56 AM |
| repairing plaster | aliG | Remodeling | 3 | 01-02-2006 08:21 PM |
