Repairing Bad Joints Before Painting - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 11:00 AM   #1
Rewards Points: 159
Repairing bad joints before painting
This job was done less then 10 years ago.
It is a vaulted ceiling with texture.
I have sections where both sides of the tape edge are peeling out.
I was planning on just pulling the old tape out and starting from scratch.
Some areas just have a slight lift on one edge - I can cut this out and feather out? Not sure how to feather into the texture.
Also a corner that has a crack running along the steel corner bead.
Not sure what to do with this.
theedudenator is offline   Reply With Quote
Old 11-21-2010, 07:26 PM   #2
ccarlisle's Avatar
I don't think you've got much choice as there's no magical solution; look tape peels and gets fixed all the time so I don't think what you've got is alien to this world...Grab the bull by the horns and get to it - or have a pro do it. The texture - whatever it is - was created originally so you either get someone to match it or create a new one.
But if the tape is peeling away, it could and should be fixed.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 11-22-2010, 02:28 PM   #3
Rewards Points: 159
I am not sure how to tape and mud with the texture present..
I am going to try to look for a pro for this one, and let me concentrate on the trim work and painting.
Not sure if I can get a pro to come out and just do these general repairs? I need to make some phone calls.
Old 11-22-2010, 02:59 PM   #4
ccarlisle's Avatar
It's a given that the texture will have to be scrapped off before retaping.
Old 11-22-2010, 04:23 PM   #5
chances are a good drywaller can repair all your problems in a day, maybe 2 depending on how he muds it. not sure what businesses will want but in my area for example i can hire a great drywaller for $200/day
racebum is offline   Reply With Quote
Old 11-23-2010, 12:20 AM   #6
A Little Of Everything
Rewards Points: 1,364
Honestly, unless you've done a lot of taping and mudding, this one is probably going to drive you crazy.
If I were you, I'd hire a pro.
DrHicks is offline   Reply With Quote
Repairing cracks and painting ext. block walls over60pirate General DIY Discussions 1 10-12-2010 02:38 PM
Repairing painting mistakes mattg43 Painting 2 03-19-2010 02:58 PM
Tape drywall joints before painting? mcraenz Drywall & Plaster 7 11-19-2009 06:28 PM
UGH! Trim joints are opening up! javan Carpentry 5 12-16-2008 06:05 AM
Repairing the wood for painting bofusmosby Painting 4 06-16-2007 11:55 PM
