Is This Repairable? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 07:04 PM   #1
Is This Repairable?
Hello All! This is my first time posting in this forum. I was moving some large furniture around my apartment and hit the protruding part of my ceiling which happens to be a corner. It left a little bit of a gash but it seems repairable. Does anyone know how I would go about repairing it with plaster (process, tools, etc.)? It is not more than a foot wide. Any help would be greatly appreciated! Thanks guys.
Jon
kingfoppa is offline   Reply With Quote
Old 08-15-2012, 07:52 PM   #2
Rewards Points: 6,652
Anything is repairable. Because that is Plaster with metal lathe, you are best to use what is commonly called "Hot" mud.
The Following User Says Thank You to gregzoll For This Useful Post:
kingfoppa (08-15-2012)
Old 08-15-2012, 08:08 PM   #3
Thanks for the help. Are you sure that it is metal? My friend said that it is concrete. Can I get hot mud at any hardware store?
Old 08-15-2012, 08:16 PM   #4
Nope, Plaster & metal lathe. The first coat of plaster in old buildings looks like mortar or some call it concrete, such as your friend. Which it is far from it.
If this is a small fix, you can get pre-mix that has the same chemical make up as hot mud but will not be as strong. I use Vinyl Spackle when doing repairs in my house which has what is called "Rock-Lathe".
Now of course, getting that corner will be hard without taking your time and properly feathering out the patch, but I am sure that you can do it.
Old 08-15-2012, 08:21 PM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
Most likely. If not Lowes or Home Depot has it.
It's the powder form joint compound that you add water and mix. You will only need to mix about a cup of the powder at a time for that size repair.
Sir MixAlot is online now   Reply With Quote
Old 08-15-2012, 08:26 PM   #6
Thanks for the help guys! Do you think I should just prepare the mix and put it on as carefully as possible? I have brushed away any loose pieces so everything is solid. Also, in your opinion, how long do you think a job will take? Sorry about all the questions. I just don't want to screw this up.
Old 08-15-2012, 08:33 PM   #7
Probably one beer while mixing and applying the mud, then let it dry, sand lightly, apply another coat of mud if it sunk a little, or you sanded too much, have another beer and let it dry. Then come back in a day and sand lightly, prime with Kilz or Zinser, wait a couple of hours and then paint.
Pretty much can be done in one day, but stuff like that I do it over a weekend, and use it as an excuse, so I can sit and watch movies and drink my favorite micro-brew.
Sir MixAlot (08-15-2012)
Old 08-15-2012, 08:41 PM   #8
Thanks a bunch. Last question...any recommendations on the brand of mix I should use?
Old 08-15-2012, 08:53 PM   #9
What Sir Mix alot posted. LaFarge is another brand, which is just as good.
Old 08-15-2012, 09:00 PM   #10
Thanks again!
Old 08-17-2012, 11:58 PM   #11
Registered User
Rewards Points: 526
It appears to be a metal corner bead, is it a coffered ceiling? Another picture would help...
If the bead is pushed in on the undamaged side - out of plane, it may still show after your repair, then you would need to cut that section out- why is the landlord not doing it? http://www.youtube.com/watch?v=AAxNL...feature=relmfu
Gary
Old 08-18-2012, 03:26 AM   #12
paper hanger and painter
chrisn's Avatar
Rewards Points: 628
Gary
You wanna bet he does not know about it?
Old 08-18-2012, 11:37 PM   #13
Registered User
Rewards Points: 526
No know... to both!
Gary
Till and reseed entire lawn or repairable? llckll Landscaping & Lawn Care 27 06-28-2010 02:37 PM
Monitor out? Repairable ? deck hand PC Repairs & Upgrades 6 12-03-2008 09:53 AM
Damaged backer board during shower tiler removal, repairable? Bobster Building & Construction 2 10-06-2008 10:00 AM
2cm round chip in bathtub - repairable? curls00 Plumbing 2 08-26-2007 12:57 AM
Which Low Slope Materials are Homeowner repairable? Basic_Homeowner Roofing/Siding 4 06-10-2007 09:26 PM
