Repair Without Tape? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 09:28 AM   #1
Repair without tape?
Hello Forum,
I recently completed a plumbing repair going into the shower wall from behind in my clients office. She is super picky about texture matching perfectly so I cut the drywall very carefully with my utility knife. My idea is to put it back using plywood backing around the perimeter with bituthane facing the repair, this would provide screw backing and air seal the repair. Then I would fill the screw holes and the seam with only hot mud applied artfully with my finger to fill the holes/seams and blend with the existing texture. Will it crack?
osb804 is offline   Reply With Quote
Old 08-26-2012, 09:37 AM   #2
Rewards Points: 13,712
Most likly.
And why the bituthane? Why would it need to be air sealed?
That's not even done if it's an outside wall repair.
Old 08-26-2012, 12:09 PM   #3
Too Short? Cut it Again!
Yes it will crack.
You can wing a small drywall patch. Cut your patch exactly 1." or so wider than the opening (depth of your utility knife blade). Then take your utility knife and carefully cut the exact size of the opening from the back up to but not through the front paper layer. Then take your utility knife and cut parallel to the surface all along the edge so you can peel the particle board material away but leave the surface paper. Press the trimmed patch in place and use the paper wings like drywall tape. Mud and finish. Hot mud works best as the premix can be too moist and cause the paper to pucker.
Old 08-27-2012, 08:53 AM   #4
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
I would first tell this lady that a patch is a patch... it is not new. You will do your best but can't guarantee a perfect match. this woman sounds like she can be a nightmare from the getgo. take the advice from all the above. you will need tape. to do it properly. I am sure you know that hot mud expands as well and will need sanding. for a picky person i would recommend not using the hot patch method but using the existing piece of drywall since the paper from a hot patch tends to bend a little bit and can make finishing difficult. Just my opinion. Not saying either way is wrong. just my preference for a "picky HO"
how to remove popcorn
stoner529 is offline   Reply With Quote
Old 08-28-2012, 12:23 AM   #5
Registered User
Rewards Points: 5,514
I agree on the edge curling from the "Cali patch" as we call them: http://www.youtube.com/watch?v=AAxNL...feature=relmfu
Don't forget to prime first... good brush trick, better than a wallpaper brush I usually use for small work.
stoner529, I've had hot mud shrink slightly (hardly noticeable), never expand, could you elaborate on that for me? What brand?
Gary
Old 08-29-2012, 01:42 PM   #6
Drywall contractor
Rewards Points: 1,070
Tape or "hot patch" if you don't want it to crack. You'll have to blend the texture as best you can. As stoner529 said, no patch is a perfect match, but you (or a drywall pro) should be able to get it close enough that it won't be noticeable to the ordinary person. You and the lady who is "super picky" will notice it because you know it's there. 99% of people walking in off of the street will never see it....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 03:45 PM
Using tape on a ceiling drywall repair janralix Drywall & Plaster 8 09-22-2011 10:07 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Scotch Edgelock Tape: My afternoon entertainment bokeh Painting 5 06-20-2011 09:17 PM
Paint pull-up!?!? with BM Aura Bath & Spa, GE Silicone II, and PM Green tape DIYatHome Painting 8 12-12-2009 03:52 AM
