Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-15-2013, 04:04 PM   #1
Repair plastic joint/bead cracks
All
My home was build by Drees and they used plastic beads at the joints (vaulted ceilings 45 degree joint) instead of drywall tape and in places this is coming loose leaving a long horizontal line either at the bottom or top. You can push on this plastic material and it is evident that it is come loose from the drywall.
What is the best way to resecure this beading/joint material and prevent this from happening again in the future?
rsscoggins is offline   Reply With Quote
Old 01-15-2013, 04:09 PM   #2
Got a picture?
Is this a mobil home?
Old 01-15-2013, 04:17 PM   #3
Not a mobile home - it is a slab foundation stick build home. Do you want a picture of the crack? It's a crack. I don't have any of the corner buld exposed at this point in time...
Looks similar to this http://www.bioplasticsolutions.com/c...d/bio_bead.htm
Old 01-15-2013, 05:57 PM   #4
You should be able to staple them back in place then do just some touch up.
Old 01-16-2013, 06:42 AM   #5
automated tool pro
if it is only stapled on, you can expect further cracking. I would pull off the bead and replace in with a vinyl composite tape. Straight-flex
drywallfinisher is offline   Reply With Quote
Old 01-16-2013, 08:16 AM   #6
The way I've been installing that stuff is sticking it in place with spray on contact cement and then bedding the mud flange with hot mud for the first coat.
chemman is offline   Reply With Quote
Old 01-16-2013, 07:01 PM   #7
you should use spray glue, staple it, and use hot mud for atleast the first coat. but if you want to repair it and never have a problem again i agree with drywallfinisher and pull it off and replace it. I would pull it off, do a prefill with hot mud. then i would apply ultra flex 325 and 450 for larger nastier corners.
princelake is offline   Reply With Quote
Cracks around inground pool. How do I repair? emory Concrete, Stone & Masonry 2 05-08-2012 08:18 PM
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 7 05-06-2012 11:43 PM
Good product to fill cracks in concrete floor wvphysics Flooring 1 10-25-2010 12:49 PM
Foundation cracks drain tile fiveoh018 Plumbing 3 06-26-2010 03:55 PM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
