Repair Or Just Replace - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-01-2012, 11:01 PM   #1
Rewards Points: 115
Repair or just replace
Looking for advice. I'm considering hiring a professional, but would like to know some things first.
My bathroom has textured and painted drywall. I had to remove some for stud repair, and then I replaced those areas with new drywall.
The issues (as pictured):
1.) The ceiling has a bad old repair above the tub where you can see tape lines. Also, various nail pops.
2.) I have an outside corner where I'll need to mud/tape unfinished drywall to textured and painted drywall.
3.) A drywall patch above the old closet will mostly be concealed with crown moulding, but one area is acting like a butt joint with two pieces of already painted and textured drywall. This area would need to be mud and taped.
4.) An old towel rack has one area of drywall pretty "banged" up. This wall is painted and textured.
So, would it be better to just tear out all drywall and pay someone to mud and tape?
Would glueing and screwing 1/4" drywall to ceiling be the easiest way to conceal all the ceiling issues?
Or, will a professional be able to easily conceal these areas?
Ultimately, I will be retexturing and repainting the entire room.
Thanks for any advice. (If a full tear out or adding 1/4" to ceiling are better options, I can do that stuff myself)
Didymus21 is offline   Reply With Quote
Old 11-01-2012, 11:20 PM   #2
Rewards Points: 14,306
There all simple fixes. Why hire someone?
Old 11-01-2012, 11:23 PM   #3
Rewards Points: 115
Lack of confidence with the finish work. The closet area will be concealed by a built in cabinet, so maybe I'll practice on those walls and see if I can do a good enough job to build confidence.
I don't know how to prep the painted/textured areas appropriately to accept new mud/tape.
Old 11-01-2012, 11:32 PM   #4
Check out You Tube, lots of videos on every step.
Old 11-03-2012, 08:23 PM   #5
automated tool pro
Rewards Points: 152
to retexture you'll need a professional or be able to spray orange peel. If it were mine I wouldnt mess with the 1/4" just get someone to fix it. It would be worth it to have it done by a pro.
drywallfinisher is offline   Reply With Quote
Pro Advice: Repair or Replace Deck ledger board and joists? jdm001 General DIY Discussions 12 09-05-2011 09:46 PM
Lots of damaged drywall - repair or replace? jdelisle Remodeling 25 04-04-2011 06:37 AM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 10:00 AM
Outdoor faucet - repair or replace? ETex2 Plumbing 2 01-19-2009 02:07 PM
Repair or replace baseboard? handbanana Painting 9 04-09-2007 06:40 AM
