Repair Jagged Bathroom Wall Demolition - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 02:51 AM   #1
We're remodeling our bathroom, but when we did the demolition job around the tub/shower area (removal of bathroom tiles and backer), we also tore off some of the plaster wall and backing adjacent to the tiled area. We've installed the cement board in the area to be tiled, but I was wondering what would be the best way to repair the non-tiled wall area? Is there a simple patching solution?
pvryderz is offline   Reply With Quote
Old 06-18-2012, 06:47 AM   #2
DIY staff
Rewards Points: 7,174
Pack that area with Easy sand (powdered drywall compound) then use paper tape and tape that in the usual manner.
Old 06-18-2012, 10:49 PM   #3
Thank you for the advice! Is it a problem if the Easy Sand touches the studs? The gaps are quite wide, anywhere from 2 inch to 6 inch wide so I'd probably fill it with lots of compound. Or maybe I should use a tarp or mesh as backing?
Old 06-18-2012, 11:05 PM   #4
jschaben
Rewards Points: 502
Just a thought - a bead of low expanding foam would plug up most of that hole and provide a surface to keep the patch material from falling through.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-19-2012, 05:04 AM   #5
DIY staff
Add in drywall patches to the wider spots---then pack and tape---(I have used foam spray to fill gaps--but this location is not a good candidate for that method)
Old 06-19-2012, 07:57 AM   #6
jschaben
Rewards Points: 502
why???
John Schaben
Old 06-19-2012, 08:06 AM   #7
DIY staff
I just looked at the pictures again---jschaben--and you might be right---those are some deeper cavities than I remembered--so that foam would be a solution---thank you---Mike---
Old 06-19-2012, 09:04 AM   #8
Rewards Points: 6,652
First thing is, that right section is going to move. Your best thing is to cut back the gypsum to allow a full sheet to meet with the sheet on the left.
The Following User Says Thank You to gregzoll For This Useful Post:
oh'mike (06-19-2012)
Old 06-20-2012, 10:06 AM   #9
Thank you for the advice! We've added the gypsum board in the gaps and filled in the rest.
Remodel vs. repair bathroom slab on grade JCTeacher Plumbing 3 04-15-2012 06:54 AM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
Bathroom wall tile demolition. zep Flooring 1 02-24-2010 10:48 AM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 11:14 PM
bathroom wall advice bigbrad123 General DIY Discussions 9 06-07-2006 08:26 AM
