Repair Hole In Drywall Installed On Concrete - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 06:21 PM   #1
Repair hole in drywall installed on concrete
Hi there,
I'm doing some basic renos in my kitchen and can do most of it, but am a bit concerned about how to repair drywall that I've damaged in the process of removing the backsplash.
The drywall is installed over concrete, and I have a rather large hole to repair. Normally, I would cut out a piece of new drywall, and mount it on existing studs or something.
But in this case, there are no studs, and I'm not allowed to drill into the concrete (condo rules). I attached a picture to help visualize.
Any thoughts on how to fix it??
optimizer is offline   Reply With Quote
Old 04-13-2011, 06:34 PM   #2
Old School
Willie T's Avatar
What is the measured size of the hole?
CLICK HERE to see an answer that might work if the hole isn't huge.
You could eliminate using the screws mentioned if the patch will stay there through the use of some mud on the back of the patch to stick it to the concrete wall.
Willie T
Old 04-13-2011, 09:38 PM   #3
Too Short? Cut it Again!
What is holding it on there now? You might need a sparse amount of construction adhesive.
You could use the flap method described in the prior post but this looks large enough I would cut the square as described and plan on taping and mudding it.
Old 04-14-2011, 09:07 AM   #4
It is a rather large hole - the exposed concrete is about 8" in diameter.
Cutting out a square section and inserting a new one held with tape and mudded over sounds straightforward - but will it hold if I plan to put a new backsplash on (i.e. will it hold the weight of the tile)?
Old 04-14-2011, 10:20 AM   #5
Drywall contractor
Rewards Points: 1,070
Use adhesive. Pretty much any construction adhesive will work. Joint compound will work also, but I'd use Liquid Nails or something like that...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-18-2011, 11:19 AM   #6
Thanks for all the tips folks - I got the work done on Sunday morning and it looks great, feels sturdy.
Thanks again
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
Gang box falls through drywall hole because its too big. Jakobud Drywall & Plaster 7 04-12-2011 09:20 PM
Hole in concrete block wall jjrbus Building & Construction 4 06-05-2010 02:32 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
Drywall and Plaster Repair argana Building & Construction 8 09-15-2007 03:13 PM
