Repair Drywall Behind Mirrored Wall That Were Removed - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-09-2009, 12:12 PM   #1
Repair drywall behind mirrored wall that were removed
We just removed a wall of mirrors. Left are the brown drywall glue spots. The wall is also orange peel textured and is a focal point in the dining room. We thought about just covering it with new drywall or wallpapering. Does anyone have any suggestions? We want to keep this 8' x 10' wall under $100.00. Thank you
Donna34655 is offline   Reply With Quote
Old 05-09-2009, 04:11 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
What you want to do is:
1. Remove any left over adhesive from the wall.
2. Remove any loose sheetrock surface paper.
3. Apply Zinnser's Gardz over the brown spots and torn paper face.
4. Upon curing/drying of the Gardz: Apply skim coats of drywall joint compound smoothly.
5. Apply the compound per normal application. Upon drying, sand smooth. (This will take 2 to 3 coats of compound to get damaged areas smooth)
6. Upon completion of smoothing out the wall area: Apply your Orange peel texture per standard application procedure.
7. Prime and Paint.
This should all be definitely under $100.00 in cost.
Good Luck on the Project.
- Build Well -
Old 05-10-2009, 04:42 AM   #3
Drywall repair
Thank you very much for the great step by step instructions. I will be waiting for Home Depot to open this morning!
Kitchen installers removed some drywall Karde Drywall & Plaster 6 05-21-2009 02:31 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Help with drywall to masonry wall kc5oh Building & Construction 5 03-31-2008 09:14 PM
wall switch repair Code3 Electrical 2 12-27-2007 03:39 PM
Minor Drywall Repair leted_82 Building & Construction 3 10-11-2007 09:57 AM
