Removing Tile / Reusing Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-22-2010, 05:21 PM   #1
Rewards Points: 18
The splash behind my kitchen counter is pretty awful. I would like to chisel off the tile & grout, refinish the drywall with powdered/premixed drywall mud, prime & paint it until I do a more serious remodel of the kitchen (that is, move windows, etc.)
Question: Is the drywall useless after I knock the tile off? Can it be resurfaced? I don't want to re-tile it now, because I'll just take it off later.
Has anyone ever tried to preserve drywall after tile has been removed?
To replace the drywall I would have to remove countertop, appliances, etc, etc. Yechhh.
(I assume that hammer and chisel is the best way to take it off....)'
Thanks.
daviswhite is offline   Reply With Quote
Old 03-22-2010, 05:56 PM   #2
Newbie Bill
Rewards Points: 520
We just did this.
We ripped off the tiles in our kitchen. Some came off easily some not so.
As some areas were really ugly I had a Drywall friend come in and he just skim coated the areas with drywall compound. His first coat was something with a bit of cementacious aspect for more strength. I don't know what is was called or even if I described it properly. But it looks great. We too will eventually re-tile.
Yes, you could just re drywall. You cut out the area between the cabinets and just replace that area. Joints will have to be done properly since it may be like that for some time.
I used a hammer and a 4 inch drywall/putty knife. Just hammered the knife between the drywall and tile. Most of them popped off without too much difficulty. Some, well, were stubborn. Hence the repair mentioned above.
Now you could also just paint the tile.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 03-23-2010, 12:45 AM   #3
jlhaslip's Avatar
Rewards Points: 914
your buddy likely used concrete filler as a first coat or 90 minute mud (fast set)
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
drtbk4ever (03-23-2010)
Old 03-23-2010, 10:43 AM   #4
Newbie Bill
Rewards Points: 520
That would be the stuff.
Bill
Old 03-23-2010, 12:36 PM   #5
Drywall contractor
Rewards Points: 1,070
Any type of setting compound will do the trick. Brown bag Durabond is the best, but not available at the big box stores, Easy-sand will do...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
drywall , kitchen , tile , tiling
Ceramic Tile on Drywall fisher501 Flooring 3 03-20-2011 05:48 PM
Removing old wood siding under drywall WaldenL Drywall & Plaster 8 09-25-2009 09:30 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
Removing floor tile glue from a wood floor mrmordun Flooring 2 09-03-2008 10:41 PM
removing a tile towel bar amyrdh Remodeling 1 05-22-2005 07:35 PM
