Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-25-2011, 01:59 PM   #1
Question
Removing sag from drywall repair
I had a leak in bedroom ceiling caused by a tub leak upstairs. Tub has been repaired and now I'm trying to repair ceiling damage. I have cut out a spot about 25''x 8'' in the drywall. When I put in my new drywall I discovered that the drywall had a sag where water had been collecting. My new drywall patch does not sag. I tried to "pull-up" the sag with my screws but it wasn't enough. Do I just fill in the sag with joint compound? Won't this take forever to dry? Help!!!
billt23 is offline   Reply With Quote
Old 03-25-2011, 02:56 PM   #2
Tizzer's Avatar
You can make up a T-shaped 2X4 prop to push the sag up. Or depending how big the sag area is, cut it out and replace with new.
Home Depot sells 2' X 2' patch squares.
Tizzer is offline   Reply With Quote
Old 03-25-2011, 04:11 PM   #3
Drywall contractor
You're better off enlarging the hole to get to a level area. If you choose to mud the difference in the pieces, use setting type compound for the fill coat.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-25-2011, 07:02 PM   #4
cut it out replace the board you will be happier and make the work easier
lrobertstoner is offline   Reply With Quote
Old 03-25-2011, 10:49 PM   #5
Thanks to everyone. I just got back from Home Depot for a larger sheet of drywall. I'll try to cut out most of the sag and go from there. Thanks again.
Billt23
Drywall Repair Questions Hurriken Drywall & Plaster 44 03-25-2011 08:02 PM
Best way to repair poor drywall installation? RyanD Drywall & Plaster 5 05-19-2009 09:13 AM
Repair drywall behind mirrored wall that were removed Donna34655 Drywall & Plaster 2 05-10-2009 05:42 AM
Removing Old Drywall Fearless Freep Drywall & Plaster 5 10-03-2008 08:48 AM
Drywall Repair + Dark Color + Repaint = Help ClemsonJeeper Painting 6 12-11-2007 09:49 PM
