-   -   Removing sag from drywall repair (http://www.diychatroom.com/f101/removing-sag-drywall-repair-99529/)
billt23 03-25-2011 01:59 PM
I had a leak in bedroom ceiling caused by a tub leak upstairs. Tub has been repaired and now I'm trying to repair ceiling damage. I have cut out a spot about 25''x 8'' in the drywall. When I put in my new drywall I discovered that the drywall had a sag where water had been collecting. My new drywall patch does not sag. I tried to "pull-up" the sag with my screws but it wasn't enough. Do I just fill in the sag with joint compound? Won't this take forever to dry? Help!!!
Tizzer 03-25-2011 02:56 PM
You can make up a T-shaped 2X4 prop to push the sag up. Or depending how big the sag area is, cut it out and replace with new.
Home Depot sells 2' X 2' patch squares.
bjbatlanta 03-25-2011 04:11 PM
You're better off enlarging the hole to get to a level area. If you choose to mud the difference in the pieces, use setting type compound for the fill coat.
lrobertstoner 03-25-2011 07:02 PM
cut it out replace the board you will be happier and make the work easier
billt23 03-25-2011 10:49 PM
Sagging Drywall ceiling
Thanks to everyone. I just got back from Home Depot for a larger sheet of drywall. I'll try to cut out most of the sag and go from there. Thanks again.
Billt23:thumbup:
