Removing Plastic Backsplash Tile - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-11-2010, 07:15 PM   #1
I am in the process of removing plastic tile from the existing backsplash. While removing some of the tiles, the grout is staying on the wall, and when I scrape the grout off, some of the sheetrock paper is coming with it. What is the proper way to do this without tearing the paper....if any way? Also, if I do tear it, what can I do to fix it? Can I mud over it and scrape away the excess and smooth it out with a sander? Or will I have to put new sheetrock in those areas? I'd rather mud that go and replace a bunch of sheetrock.
ws450r is offline   Reply With Quote
Old 07-12-2010, 12:01 PM   #2
Newbie Bill
Rewards Points: 520
Are you going to put new tiles on this?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 07-12-2010, 12:43 PM   #3
Yes, but not plastic.
Old 07-12-2010, 12:49 PM   #4
Newbie Bill
Rewards Points: 520
Ok, I think as long as the damage to the drywall isn't too bad, you can just mud over it and sand. Then you can install your tiles overtop of that.
Hang on for awhile longer until one of the experts chimes in.
Bill
Old 07-12-2010, 01:33 PM   #5
This is what my brother said. He has done some work like this and knows more about it than I do. I don't have a problem with leaving it, but in the time being, I won't be putting up new tile very quick, and at this point with me, its just aesthetics that don't look good until I finish it.
Old 07-12-2010, 01:37 PM   #6
Newbie Bill
Rewards Points: 520
We are in that in between stage ourselves. Old tiles removed in December along with chunks of drywall. Drywall contractor put a couple coats of mud (a cementacious mud mix) and sanded and it looks fine. It will likely will be another couple of months before we begin putting tile up.
Bill
Bullnose corner tile for backsplash golfgirl Tiling, ceramics, marble 5 03-05-2010 06:11 PM
Tiling / backsplash question Mark755 Kitchen & Bath Remodeling 4 02-26-2010 01:01 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 10:49 AM
removing objects from tile wall lanaj7206 General DIY Discussions 5 06-30-2008 06:55 PM
Plastic shower surround on top of tile ok? 1973vw Remodeling 4 04-09-2008 12:22 AM
