Removing Plaster Painted Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 06:24 AM   #1
removing plaster painted ceiling
want to remove painted textured ceilings. They are a plaster base finish and have been painted several times. I here this can be quite the job.
Would it be best to simply remove old dry wall and replace or add another sheet of dry wall over existing dry wall.
madely2001 is offline   Reply With Quote
Old 03-10-2011, 10:04 AM   #2
It would be much easier to put another layer of sheetrock over the existing ceiling. Using longer screws, 1 5/8" or longer depending on what exactly you are going over. I have done this many times. Removing the existing ceiling will be quite messy. Still be sure to go perpendicular to the framing members. And if you don't use ceiling sheetrock, then you will want to use 1/2" on 16" centers and 5/8 on 24" centers. Also remember that you are going to be covering the ceiling so you can put holes in the old ceiling if necessary to find the framing members or for relocating lights.
redmanblackdog is offline   Reply With Quote
Plaster ceiling - want to install down/can lighting with least mess/needed patching swaff Drywall & Plaster 3 10-21-2010 06:28 PM
Kraft paper on ceiling joists for plaster jefsboys Building & Construction 0 09-30-2010 12:08 PM
How to remove plaster bathrom ceiling. scotty8 Building & Construction 2 10-25-2009 12:35 PM
Is my contractor suggesting the correct way of redoing plaster ceiling? karenldee Building & Construction 7 10-23-2009 10:47 PM
Removing painted popcorn texture from ceiling cnielsen4130 Remodeling 8 10-07-2007 11:21 PM
