Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-28-2011, 05:01 PM   #1
Removing plaster ceiling texture
Not drywall, I know, but couldn't find a better place to put this.
We have an older home (1960's) with a textured plaster ceiling in the dining room that kind of looks like THIS. I'm not typically opposed to textured ceilings, but this one was done by somebody with NO skills. Some of the 'peaks' are 1/2" long, some places have almost no texture, others you can clearly see the shape of the sponge they used to apply it. Is there a easy way I can remove this myself? Maybe scrape it off and skim some patching plaster over it?
syogod is offline   Reply With Quote
Old 12-28-2011, 05:06 PM   #2
Looks like popcorn. Lay plastic down and try wetting it down with a pump sprayer with warm water and a dash of liquid fabric softner or dish soap.
Let it sit a few min. then try scraping it with a dry wall knife.
Still stuck hit again and let it soak in.
Old 12-28-2011, 05:31 PM   #3
Disabled wood vet
titanoman's Avatar
I didn't know you had to get it wet.
titanoman is offline   Reply With Quote
Old 12-28-2011, 05:42 PM   #4
Not coming down unless you do. If it's been painted it still may not come down.
Old 12-31-2011, 05:50 AM   #5
From what he's describing I'm thinking this is probably not popcorn. Popcorn wouldn't have 1/2" peaks. It sounds more like the mud stamping done in the 60s and 70s to avoid drywall finishing.
That stuff isn't quite as easy to scrape off as popcorn. I cannot find the site for the life of me but a DIY guy details his method of removing it. I've removed it in one room at my mother's house and we ended up using an orbital sander to knock it down as close as we could. She ended up with a finish almost like a stucco.
If this is what you're dealing with you're going to need a sander and some patience. Don't sand so harshly that you break the face of the drywall paper and use nothing more absrasive than 80 grit sandpaper. It will be nearly impossible to get a completely flat finish ceiling.
Popcorn, on the other hand, can just be misted with a spray bottle or garden hose and scraped off with 10" knife very easily.
JustADoc is offline   Reply With Quote
Old 04-22-2013, 04:56 PM   #6
We have a home that was built in the 70's.The ceiling I believe is a stamped design, has started peeling away from the ceiling in living and kitchen area it has been painted at least twice, and I was wondering what procedure I should take on repairing it or do I just remove the sheet rock and start over? I saw somewhere that I could use plaster of paris and joint compound to smooth the texture out after sanding down the texture ceilings.I'm asking for advice I need help I can't look at this ceiling any longer. I' unemployed now and need the least expensive way out.
jcatherleen is offline   Reply With Quote
Old 04-22-2013, 07:46 PM   #7
J it would be best to go back and add your own post not just add onto someone lese so it does not get confusing who's talking to who.
Also post a picture.
Please edit your profile so it shows your location!
No one here knows exactly where on the planet you may be so how can we ansewer a code, building, or insulation question without it?
Old 04-23-2013, 02:38 AM   #8
sdsester's Avatar
I am confused. The OP says you have a plaster ceiling. Is this true or do you have some sort of plaster-ish texture over drywall?
If it is drywall, it may be faster to just take it down and replace it then trying to sand all the texture off of it.
If it is popcorn or a cheap textured spray on ceiling it may come off when moistened and with a wide drywall blade.
You do want to be careful getting a plaster ceiling wet though and your best bet may be to sand it off, if you can. You may end up having to put another drywall layer over it if the ceiling itself is in good shape. A layer of drywall is an option if it is a textured drywall ceiling too. Something like 1/4" is often used.
I personally do not like layering ceilings up this way but would not take a plaster ceiling down that was in good shape.
sdsester is offline   Reply With Quote
Help Removing Mt. Everest Ceiling Texture captainehh Drywall & Plaster 29 02-16-2011 06:44 PM
Popcorn ceiling made of plaster strungoutfan78 Drywall & Plaster 9 01-26-2011 11:25 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Is my contractor suggesting the correct way of redoing plaster ceiling? karenldee Building & Construction 7 10-23-2009 11:47 PM
Ceiling Texture Matching MJBhoya Painting 3 02-08-2009 11:04 PM
