Removing Painted Popcorn Texture From Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 01:48 PM   #1
Removing painted popcorn texture from ceiling
We are in the middle of remodeling my kitchen and wanted the popcorn texture removed. The dining room (unpainted) went smoothly but as we got into the kitchen area (painted), we had a hard time removing the popcorn texture. I had painted of it a couple of years ago with latex paint and it would not scrape off....even with water. We ended up using a paint remover and rolling it on a little at a time.
Norva is offline   Reply With Quote
Old 02-01-2010, 01:14 AM   #2
You can drywall over the popcorn or buy a scraper. Either way, there will be a lot of patching and mudding. Go to Home Depot and in the paint aisle there is a tool about 8-10" long with a 4" razor blade on the end of it. Get that and scrap the popcorn off. Once you get past the paint, water should help dissolve whats left. Its not an easy or quick job.
jonathan03 is offline   Reply With Quote
Old 02-01-2010, 09:32 AM   #3
I did a light scrape on my popcorn ceiling leaving the base texture on the ceiling
Be aware that asbestos may be in the older popcorn ceilings
Old 02-01-2010, 03:30 PM   #4
Too Short? Cut it Again!
The sure fire way to get it to come off is to trick it. Make believe you are trying to paint it and it will stick to your roller cover in seconds. I have said before and will say it again. Popcorn ceilings are the work of the Devil!
Seriously, with patience, I can usually get most of it if I can grab a corner and get my thin, wide drywall knife under it. Sounds like you have tried this though.
My Fein multi-tool has actually come in handy for this a time or two. One of the many things I never thought I would ever use it for. You might think about one of the cheaper alternatives out there if you don't want to spend the money on Fein. I do use mine all the time. It is one of the best tool investments I ever made.
I've also got a large orbital sander that sometimes works but you have to feed it a fair amount of paper. Do heed Dave's warning about potential asbestos. Where a temp jumpsuit and regardless of what it is a mask or aspirator. Block the dust from getting to your furnace cold air returns if that is the system you have.
Old 02-02-2010, 11:10 AM   #5
One tool that I have used in the past is a plain old brick. It also works for removing painted on sand.You also get really big shoulders
antlerdancer is offline   Reply With Quote
Old 02-02-2010, 11:24 AM   #6
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
I painted my popcorn ceilings with the Glidden ceiling paint that goes on pink and dries white using a 1 1/4 Purdy nap and had very little issue with the popcorn coming loose. Maybe because it had been painted so many times before? 45 year old house.
I ended up tearing down the ceiling anyways, later on in the project
brons2 is offline   Reply With Quote
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 03:37 AM
Trends in 2009: POPCORN TEXTURE IS BACK! studiobarb Interior Decorating 11 09-02-2008 06:26 PM
Best way to texture a bathroom ceiling DIY-Renovator Painting 3 07-30-2008 09:49 AM
Removing painted popcorn texture from ceiling cnielsen4130 Remodeling 8 10-07-2007 11:21 PM
Retexturing painted popcorn ceiling kwehnes Building & Construction 6 01-02-2007 04:36 AM
