Removing JC From Inside Corners - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 01:11 AM   #1
Rewards Points: 243
Removing JC from inside corners
A lot of my vertical inside corners have failed in my house. The old tape was set on top of huge uneven blobs of JC and then a super thin layer (I can see the tape through the JC) was applied over top. What's the best/easiest way to remove the excess JC from the corner so that I can re-tape the corners? I was thinking either coarse sandpaper on a block or orbital sander, or a nice sharp 1.5" chisel to shave it down close to the paper.
chemman is offline   Reply With Quote
Old 05-30-2012, 07:25 AM   #2
Rewards Points: 13,444
Post a picture.
By the sounds of it you need to remove the tape and start over.
Trying to sand it is just going to leave you with bare spots and fuzzy tape to deal with.
Old 05-30-2012, 11:02 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 280
Try a wet bath cloth, it will soften the JC.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 05-30-2012, 02:37 PM   #4
Rewards Points: 243
The tape is already down, I'm talking about what I found underneath. I'll try to get a picture, but I'm not sure what I'm talking about will show up.
Old 05-30-2012, 07:36 PM   #5
In the past i have used a paint scraper ( the kind that you pull while scraping) when i have had to remove build up after removing old metal corner bead when filling in a wrapped opening.
kj6887 is offline   Reply With Quote
Old 05-31-2012, 09:29 AM   #6
Rewards Points: 243
Do you have a picture or a link? I've never heard of such a thing.
Old 05-31-2012, 10:30 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 280
http://www.google.com/products/catal...d=0CK4BEPMCMAI
Jim
The Following User Says Thank You to BigJim For This Useful Post:
kj6887 (05-31-2012)
Old 05-31-2012, 06:41 PM   #8
Thanks Jim I am not very tech savvy
Old 06-01-2012, 01:17 PM   #9
Rewards Points: 1,450
Flathead screwdriver/chisel and a hammer sound like they would work in this situation.
mikegp is offline   Reply With Quote
Health safe coating for inside of rice bin Homerepairguy General DIY Discussions 8 08-15-2011 02:14 PM
Taping Inside Angle with Tapered Edges project_guy Drywall & Plaster 2 03-08-2010 06:49 PM
Siding Inside Corners scott j Building & Construction 11 03-03-2010 06:30 PM
Gutter apron at inside, outside corners oldgrunt Roofing/Siding 3 12-22-2008 05:01 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
