Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-02-2013, 02:57 PM   #1
Removing durcock with ceramic tile attached?
How do you remove durock with ceramic title attched in a bathroom wall?
pgriswold is offline   Reply With Quote
Old 03-02-2013, 03:04 PM   #2
Got a picture?
Is it inside the tub area?
Old 03-02-2013, 03:29 PM   #3
Don't have a picture. The durock surrounds above a regular bathtub. We have ceramic tile on the durock. The durock is right above the bathtub on three sides. pgriswold
Old 03-02-2013, 03:58 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
Get above it, and slip a flat pry bar behind, between the stud and the durrock. Otherwise, pull the tile off first, then you can cut into the durrock and pull that way. The screws should be easy to find, once you pull the tile.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 03-02-2013, 05:23 PM   #5
Line that tub with cardboard and plug the drain before doing anything.
Old 03-03-2013, 09:35 AM   #6
automated tool pro
line the tub with something soft. If you get a piece of tile durorock thin set under the cardboard it will grind it into the tub. Insulation works real good.
Did you buy a drywall hammer and have a regular framing hammer? Use a razor knife and score the wall up next to the tile. Then do what the first guy said. Find a stud over the tile and instead of the pry bar use the hatchet side of the hammer, and hammer it into the rock above the tile over the stud. pry the first section of the durarock loose. repeat this all the way around the tub. I use a drywall hammer for prying because I can also use it as a chisel. Find spots that need to be split and removed it section. Tile and durock are like a giant piece of stone that will split when hit with enough force through the ax end, chiseling like a stone carver. It may seem kinda far out, but being able to remove the section in pieces will make for a cleaner area.
drywallfinisher is offline   Reply With Quote
Old 03-04-2013, 12:06 AM   #7
Careful! That concrete board is heavy and broken ceramic tiles are very sharp. Here's what happened to me when I was tearing out my tub surround...16 stitches in my lower leg!
Removing durcock with ceramic tile attached?-forumrunner_20130303_230544.jpg
Kansas Girl is offline   Reply With Quote
The Following User Says Thank You to Kansas Girl For This Useful Post:
cleveman (03-09-2013)
Old 03-09-2013, 08:28 PM   #8
Handyman
I cut a piece of 5/8" ply 58" x 33". I glued scrap laminate underlay around the perimeter and I use this when tiling tub ceilings so as not to scratch the tub, but also provides me a comfortable height to install tile..Also provides a cushion in case a tile falls
canadaclub is offline   Reply With Quote
The Following User Says Thank You to canadaclub For This Useful Post:
oh'mike (03-09-2013)
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 02:59 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 10:39 AM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 08:58 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
