Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-30-2011, 01:41 PM   #1
removing drywall from stud
I'am removeing drywall thats been glue on to the stud but it dosen't seem to to wanted come away from the stud the papper and drywall stay there. what can i do to remove it from the stud, or the best way to remove it thank you
gtw010 is offline   Reply With Quote
Old 01-30-2011, 02:20 PM   #2
Super Moderator
I use a large chisel or a painters tool--and a hammer----just chisel it off---Mike---
oh'mike is online now   Reply With Quote
Old 01-30-2011, 02:39 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
gtw010, If you have alot to remove. Get the Dremel Multi-Max Oscillating Kit
This could be the best $89 you ever spent.
-Paul
Checkout some of
Sir MixAlot is offline   Reply With Quote
The Following 2 Users Say Thank You to Sir MixAlot For This Useful Post:
Axecutioner-B (01-30-2011), Thurman (01-30-2011)
Old 01-30-2011, 10:20 PM   #4
Super Moderator
Those multi tools are the handiest things---we dubbed mine " the super tool"
Comes out of the truck almost every day----
Old 02-02-2011, 04:35 PM   #5
Drywall contractor
It's my new favorite "go to" tool also. Haven't tried it in this application yet, but it could just be the answer to the annoying "glue on the stud" issue. A good stiff scraper or painters tool has been my method in the past....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-02-2011, 05:03 PM   #6
Professional Painter
Cut out all your can, then tap the drywall until it comes off....It'll be messy, but it'll come off.
mattroefer is offline   Reply With Quote
Removing Drywall for Repairs BJH Drywall & Plaster 22 01-29-2011 03:22 AM
Condo Bathroom Reno (CBU, Drywall, tiling, basic plumbing) LeviDIY Project Showcase 34 10-31-2010 08:56 PM
Removing Tile / Reusing Drywall daviswhite Drywall & Plaster 4 03-23-2010 12:36 PM
Removing drywall for wiring Klawman Drywall & Plaster 6 03-17-2010 10:36 AM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 12:35 PM
