Removed Wallpaper But Didn't Clean Before Skim Coat - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-04-2013, 01:32 AM   #1
Rewards Points: 452
Removed wallpaper but didn't clean before skim coat
did I screw up big time?
I wetted the wall, and scraped off most of the wallpaper. I scraped pretty hard, so most of the gunk came off. However, after drying, there was a tiny bit of stickiness.
The walls are painted with flat paint. and I just put all purpose joint compound over whatever invisible bit of wallpaper paste residue was there.
Will the skim coat fail? or will the joint compound glue hold?
If it all doesn't fall off tomorrow, could I leave it alone?
pman6 is offline   Reply With Quote
Old 06-04-2013, 04:39 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
You MIGHT be alright. I would certainly prime with Gardz or an oil based primer, like Cover Stain
Old 06-05-2013, 12:47 AM   #3
Rewards Points: 452
I went back today, and the skim coat seems to be hanging on.
sanded hard with 80 grit, still intact.
Then put on another coat to fill the defects from first coat.
hopefully this means it will last.
Old 06-05-2013, 05:03 AM   #4
chrisn's Avatar
Rewards Points: 124
You should still prime it
skim coat or rip it down?#$! MGravie Drywall & Plaster 1 11-17-2012 08:06 AM
Fix Bad Skim Coat Job smoline Drywall & Plaster 8 09-21-2012 10:36 AM
Second topcoat blisters over clean skim coat norepeat Painting 8 09-07-2011 07:30 PM
Removed wallpaper and i want to paint now ldholiman Painting 3 02-18-2009 07:28 PM
How to Skim Coat Walls LeahMia1995 Remodeling 2 03-07-2008 02:25 PM
