Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-19-2013, 11:01 PM   #1
Removed 4" formica backsplash - how to repair wall?
Yanked out formica in favor of granite. Took out the 4" backsplash in favor of a tile backsplash that I will do myself. I'm just not sure how to repair the wall before beginning tile work. There seems to be a tiny horizontal gap here and there right at the top of where the backsplash was. I am not sure what that's about. Should I re-drywall this section or spackle it or what?
cwb124 is offline   Reply With Quote
Old 03-20-2013, 08:58 AM   #2
Cut off the loose paper, prime, then a thin coat of drywall compound, sand, do again if there's any bad low spots.
I'd prime again then install the back splash.
I'd use at least an 8" knife, wider the better so it will follow the soild wall.
Make sure to use a putty knife to get off any old caulking before starting.
The time to repaint the whole wall would be before the back splace goes in if it's needed so there's no cutting in.
Old 03-20-2013, 10:07 AM   #3
Bill Kearney
Yeah, if you're going to paint the rest of the wall (not the part covered by the backsplash) do it now to avoid the hassle of masking the tile off later.
Not sure you'd have to repair that wall if you're just going to put tile over it, especially not if it's higher than the old backsplash line. Just make sure to properly caulk the bottom edge, not use grout. Where tiles meet other surfaces you want something that'll seal AND be flexible (grout does neither). So be ready to get colored caulk when you're selecting the grout color (which may lead to planning around the available caulk colors you can find).
wkearney99 is offline   Reply With Quote
Old 03-20-2013, 10:38 AM   #4
Oddly enough the kitchen was recently painted.
My concern about the drywall is with loose paper and such, it won't hold the tiles securely. Its also somewhat uneven now as well so I think that needs to be al straightened out. I think the idea of removing any excess paper and priming is probably a good bet. Then going over it all with spackle to bring everything up to the same level. Then I have a nice even surface to start the tile backsplash on.
After I spackle, do I need to prime again for the tile adhesive, or can I glue the tiles right to the sanded down spackle?
Old 03-20-2013, 10:40 AM   #5
Just reread my first post.
And spackle is for small nail holes not for this job. Yes there's a big differance.
Old 03-20-2013, 10:48 AM   #6
Bill Kearney
Yeah, if the surface is uneven enough then smoothing it with joint compound (not spackle) would be a good plan. Bear in mind you may need to apply the compound in layers as if it's too thick it may have problems drying evenly and end up cracking. Using thinset gives you a little more chance of a working thickness, whereas mastic generally does not.
Old 03-20-2013, 11:12 AM   #7
Sorry, I mistakenly used spackle for drywall compound. Sounds like I have a plan.
I am slightly concerned about a couple spots where I think the contractors prybar poked some holes in my drywall when removing the formica backsplash. I might have to cut some out and replace it. Or should I not be too concerned?
Old 03-20-2013, 11:19 AM   #8
Remove the loose stuff and paper tape and mud that area.
Old wall repair anonymoose Building & Construction 0 09-03-2012 03:28 PM
Fixing apartment wall (drywall/stud repair) DIY_Jon Building & Construction 5 12-06-2011 09:05 PM
Vanity backsplash 1" from wall jellerysaunders Kitchen & Bath Remodeling 8 05-02-2010 12:13 AM
Repair drywall behind mirrored wall that were removed Donna34655 Drywall & Plaster 2 05-10-2009 05:42 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
