Remove Wallpaper From Plywood - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 09:18 PM   #1
Question
Remove wallpaper from plywood
A previous owner "drywalled" my 100+yo house with 1/4" plywood and then glued wallpaper on it with Elmers or something similar.
The wall paper was put on very nicely except for the choice of adhesive, but it is not to my taste.
I have tried steam, hot water, hot water + vinegar, hot water + detergent, and when the steam didn't work right away I tried with a paper tiger (then all the other stuff). I can't get any of it off. The only place it comes off is one corner where the settling of the house has loosened it.
Any suggestions how to get it off, or should I just skim it with joint compound and prime/paint over it? One thing to consider is that the house is pier and beam and moves a LOT.
Thanks!
Metra is offline   Reply With Quote
Old 03-26-2011, 04:25 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Thanks!
Sounds as if this is you're only choice. Be SURE to use an oil primer, stain blocker.
Old 03-26-2011, 09:19 AM   #3
Thanks!
Tags
elmer's glue , plywood walls , wallpaper removal
Wallpaper Removal Choices in Kitchen LeviDIY Painting 14 12-02-2011 04:30 AM
Does the plywood have to come out? AGH! JP6044 Tiling, ceramics, marble 7 01-31-2011 01:20 PM
To remove wallpaper or just re-drywall interplexr Painting 12 01-14-2010 01:48 PM
Remove Plywood Subfloor? cpbraun Flooring 3 11-20-2006 09:24 AM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 01:13 AM
