-   -   Remove wallpaper from plywood (http://www.diychatroom.com/f101/remove-wallpaper-plywood-99569/)
Metra 03-25-2011 09:18 PM
A previous owner "drywalled" my 100+yo house with 1/4" plywood and then glued wallpaper on it with Elmers or something similar.
The wall paper was put on very nicely except for the choice of adhesive, but it is not to my taste.
I have tried steam, hot water, hot water + vinegar, hot water + detergent, and when the steam didn't work right away I tried with a paper tiger (then all the other stuff). I can't get any of it off. The only place it comes off is one corner where the settling of the house has loosened it.
Any suggestions how to get it off, or should I just skim it with joint compound and prime/paint over it? One thing to consider is that the house is pier and beam and moves a LOT.
Thanks!
chrisn 03-26-2011 04:25 AM
Thanks!
Sounds as if this is you're only choice. Be SURE to use an oil primer, stain blocker.
Metra 03-26-2011 09:19 AM
Thanks!
