Remove Drywall Installed Over OSB - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-03-2011, 05:11 PM   #1
Remove Drywall installed over OSB
Does anyone have any tricks for removing drywall that is installed over OSB sheathing. I have about 200 sq ft that I need to removed and looking for an easy way to remove the drywall.
Jay
jrunde is offline   Reply With Quote
Old 03-03-2011, 08:21 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Easy?
How can we suggest anything if you can't tell us how the drywall is installed?
Is it nailed, is it screwed, is it glued, is it stapled?
What if there is no "easy" way then what?
XXX
Old 03-04-2011, 12:38 AM   #3
from what ive been able to tell from the few square feet i pried off with a crow bar, it is nailed on.
Old 03-04-2011, 11:37 AM   #4
keep prying it off with the crowbar...
Could set a skill saw at the depth of the drywall, but it really sucks when you hit a nail...
williamwiens is offline   Reply With Quote
Old 03-04-2011, 02:26 PM   #5
Handyman
Rewards Points: 512
Not to mention the dust Out of curiousity, why do want to remove it?
canadaclub is offline   Reply With Quote
The Following User Says Thank You to canadaclub For This Useful Post:
boman47k (03-04-2011)
Old 03-04-2011, 04:24 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I don't get it!
If it isn't glued it should pry up and off easily. Then just pull the nails afterward.
How easy does it have to be for you to be able to do it?
XXX
Old 03-04-2011, 05:21 PM   #7
Handyman
Rewards Points: 512
There must be something more to it. OSB is not the best material to hammer drywall into. Like hammering on a trampoline
Old 03-04-2011, 06:15 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I love it!!!
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Old 03-04-2011, 07:42 PM   #9
Rewards Points: 530
I don't know why it would be nailed over osb, but if the studs were hit, why would bounce.
I learned my lesson a long time ago about using a skill saw to remove drywall! Hehehe, never again inside a house.
And I only cut enough out of a wall to add a couple of outlets, maybe 9' x 14".
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
What's the best way to remove Plaster/Lath walls and replace with Drywall psubaron Building & Construction 31 02-14-2011 11:20 AM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Cutting Drywall Cleanly??? Tom5151 Drywall & Plaster 5 10-05-2009 04:26 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
