Removal Of Sand Texure From Drywall Surface - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 01:04 PM   #1
Rewards Points: 258
I've read that the old texture surfaces such as the common sand finish on ceilings can be removed with soap & hot water and skimming the old surface off with a sheet rock knife to prep for a new sand texture finish prior to painting.
Has anyone tried this method? Any advice?
Docfletcher is offline   Reply With Quote
Old 01-15-2012, 08:17 AM   #2
Remodeling Contractor
popcorn and similar textures can be removed this way. Sand texture is a bit more tenacious and will require scrapping. You could use this method since the sand coat is not very thick. Water down a tub of compound to the consistency of pancake mix. Apply with a paint roller. Then scrape off evenly with a large drywall knife held at a 45 degree angle. Do not apply too much pressure. You are simply applying an even coat to fill in over the sand.
Old 01-15-2012, 01:00 PM   #3
Rewards Points: 13,694
Why would you want to smooth it out, then go back over it again with the same thing?
Sand finish is next to impossible to scrape off because it's likly sand mixed in with the paint.
Old 01-15-2012, 02:02 PM   #4
Rewards Points: 258
Well, I'm trying to save the ceiling and skylight areas. When I coat with sand texture again I want it all to match. I thought sand on top of sand might look odd. Was I wrong?
Old 01-15-2012, 02:09 PM   #5
It would be better to have no texture at all, easer to clean and paint.
Put if your going with a snad finish any way I'd be tempted to try an area to see what happens by just going over what you have now with another coat of sand mix in the paint.
Far less work and mess then trying to skim coat it.
Old 01-15-2012, 02:50 PM   #6
Rewards Points: 258
Well I'm kind of committed now to either finish removing the sand/grit old surface and then re-coating. Or just pulling the sheet rock down and replacing it.
On the plus side there is nothing under it all but an old floor that will be getting ripped out. Thanks for your help.
Old 01-15-2012, 02:59 PM   #7
Once again for less mess just go over it with new drywall if you decide that way. Use 3" screws and make sure your hitting the rafters.
I do some test drilling first and once I find them I add painters tape on the wall to mark them.
Old 01-15-2012, 03:26 PM   #8
Rewards Points: 258
Joe, Thanks, a great idea. I think that would work. I would just need jumbo corner bead. I'd use 3/8 rock. Lighter & easier to handle.
Old 01-15-2012, 03:49 PM   #9
Why the wide corner bead?
Do not use less then 1/2" if you do not want it to come down from screw pops and it also would sag.
Use drywall adhesive.
Rent a drywall lift for a few hours and you could use 5/8 drywall and install it with one person. Two if there's a few corners to get around.
Old 01-15-2012, 06:56 PM   #10
Rewards Points: 258
Adding a sheet of 1/2" brings one leg of the bead past the past the ceiling 2x4 nailer. Any nail placed there would go into the edge of the sheet rock.
Is there a drawback to using the jumbo?
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 04:34 PM
Complete drywall removal - old house diverdaveman Building & Construction 5 06-22-2007 03:17 PM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 05:41 PM
