Remodeling Kitchen Oops? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-29-2014, 08:39 AM   #1
We had our cabinets and countertops replaced. We are moving from laminate to granite countertops. The contractors removed the laminate backsplash. By removing the backsplash, they exposed the gypsum underneath the drywall paper. Do I have to completely replace the drywall, or is there a way to repair the drywall without completely replacing it. We are putting in tile backsplash, in so the drywall doesn't need to be primed or anything, just need something that the tile will stick to.
jodisgoing180 is offline   Reply With Quote
Old 04-29-2014, 08:42 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 820
Attach 1/4" hardibacker to the wall. That will give you a great surface for the tile....and will be a whole lot flatter than the drywall.
Just be aware that you will will need box extenders for your outlets....common when doing tile for a back splash...
ddawg16 is online now   Reply With Quote
Old 04-29-2014, 09:01 AM   #3
DDawg-- Do I have to remove the existing drywall to install the 1/4" hardibacker? Or can I just install on top of the gypsum?
Old 04-29-2014, 09:12 AM   #4
Rewards Points: 12,830
We can not see what your seeing without a picture.
Minor damage can be primed with Gardz primer then skim coated with drywall compound.
Sand smooth and tile over.
Saves you from having to deal with the outlets, any window trim, the small step on the outside edges if you use tile board.
Old 04-29-2014, 09:31 AM   #5
DIY staff
Rewards Points: 7,174
Rather short sighted planning----the drywall should have been replaced during demolition---
Now you are in for a lot of extra work.
Overlaying the drywall with backer board is not usually an option---that makes the wall to thick--trim won't line up--caps/bullnose tile can't be used as a finished edge---
Remove the drywall and replace or patch the old torn up stuff---what a mess---why was the old stuff left when the cabinets were removed?
Old 04-29-2014, 10:54 AM   #6
Rewards Points: 5,974
Without a pic this is just a guess. Use Red Guard or something similar to seal the existing drywall. Then use the thin set for your tile to level and set the tile.
Kitchen remodeling dinosaur1 Kitchen & Bath Remodeling 70 03-20-2014 12:37 AM
Kitchen floor tiles. ABurch Kitchen & Bath Remodeling 1 12-06-2012 01:35 PM
Remodeling a 1920 kitchen fix what? Remodeling 10 06-20-2012 09:54 PM
remodeling kitchen and need electrcal help! joeronimo Electrical 4 12-27-2005 09:51 PM
kitchen and bathroom remodeling Grumpy Remodeling 11 02-10-2005 02:35 PM
