Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-04-2012, 09:30 PM   #1
Regular and setting compound
Drywallers started taping my house today. First, they taped with premixed USG compound (blue) and then, immediately put on the second coat using a setting compound (USG 45). I've been told this could result in bubbles, lose tape, etc. Does anyone have any experience with this?
Bob the is offline   Reply With Quote
Old 06-04-2012, 09:37 PM   #2
May want to check on the USG site on that one.
I've working on hundreds of houses and have never once seen it done that way.
Old 06-05-2012, 04:39 AM   #3
(the original)
Sounds bass-ackwards to me...
ratherbefishin' is offline   Reply With Quote
The Following User Says Thank You to ratherbefishin' For This Useful Post:
Willie T (06-05-2012)
Old 06-05-2012, 05:23 PM   #4
it depends on how wet and thick the mud is underneath . being a taping coat is pretty tight and dries fairy quick your probably ok.
oldrivers is offline   Reply With Quote
Old 06-05-2012, 06:50 PM   #5
ya it can be done that way but i dont recommend it but to each their own. usually you use 45 for first coat then second you go to a premix. if theres no bubbles now then they are fine and you have nothing to worry about.
princelake is offline   Reply With Quote
does setting compound need tape? redline9k Drywall & Plaster 8 01-08-2012 02:27 AM
Tape with Setting Mud - Yay or Nay mobiledynamics Drywall & Plaster 3 11-09-2011 01:16 AM
"Quick" setting mortar for acrylic tub bedding countryman Plumbing 0 05-24-2011 06:21 PM
Reoccuring drywall crack loehrm Drywall & Plaster 2 03-17-2011 08:28 PM
Drywalling question (heatsource) richardremodeler Remodeling 5 07-03-2007 12:52 PM
