Reeeeeeally Long Ceiling And Wall Cracks - What The? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 05:12 PM   #1
Reeeeeeally long ceiling and wall cracks - what the?
I'm looking to buy my first house soon, on the northern California coast. I finally found a house I can afford in the over-priced college town where I work (have been looking at the town south of here, mostly), BUT it is an estate sale being sold "as is." And when I looked at it w/ a realtor, we saw that there are MANY long cracks in the ceiling and walls, some of them beginning in one room and ending in another. Some are vertical, some horizontal, and some diagonal across ceilings, anywhere from a foot long to 14 feet or perhaps more. They look deep but I can't tell how deep. Some of them have been patched over in white but you can still see the cracks beneath. The house was built in 1947. Is this a sign of problems with the foundation? Does the drywall need to be replaced?? (not sure if that's in my budget for this particular house, being located in the trendy town it's in).
I know extreme variations in humidity can crack drywall, but this is an area that's pretty much just always humid, with not a lot of variation in temperature (lowest temp in winter usually around 36, highest in summer is maybe 80 if we're lucky and get a "hot" day). Also, I don't see water damage in the house, which is unusual (most houses I've looked at here have water problems because of all the rain - think Seattle weather).
Is this a house I should just run screaming away from??
(I'd post photos, but I took them on my phone's camera and lost the usb cord for it -- d'oh!)
TOTALN00B is offline   Reply With Quote
Old 03-05-2011, 05:18 PM   #2
BIGRED
Rewards Points: 252
Does earthquake ring a bell?
Grampa Bud is offline   Reply With Quote
Old 03-05-2011, 05:23 PM   #3
that was my first thought but figured to easy. If it was a one time deal and cali never has quakes again repair of wall covering may be all that's needed
The older I get the better I was
Old 03-05-2011, 06:14 PM   #4
Well, that was the first thing I thought of, but as I looked online at "reasons for ceiling and wall cracks," it seemed there were a gazillion other possibilities, which scare me more. One site (I think it may have even been 'This Old House') said that horizontal and vertical cracks are OK, but not diagonal (which this house has), because it indicates foundational problems...(?) Our last big quake up here (6.5) was last January, and I had only heard of damage in the town 20 minutes to the south, where I live now, which was much closer to the epicenter. And even here it wasn't so bad. No cracks in my walls or ceilings, or those of anyone else I know...So could this mean the house I'm looking at is poorly built somehow, if none of the surrounding houses, or ones closer to the quake, have earthquake damage?
Old 03-05-2011, 06:22 PM   #5
Learning by Doing
Leah Frances's Avatar
N00B - this house is starting to look pretty scary.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
TOTALN00B (03-06-2011)
Old 03-05-2011, 06:42 PM   #6
BIGRED
Rewards Points: 252
Cracks of any kind mean something has shifted. Could be dry rot, termites, foundation settling, soil compaction caused by underground water, poor or incorrect construction, a remodel gone wrong, the possibilities are only limited by your imagination. The wider or longer or more diagonal the crack(s) the more the problem has been exaserbated. How handy are you? How much money are you willing to spend to correct the problem? How long do you plan on owning the property?
The Following User Says Thank You to Grampa Bud For This Useful Post:
Old 03-06-2011, 10:41 AM   #7
My guess is that the house was plastered originally and that the plaster has run its life. Plaster is only good for about 50 to 60 years. If that is the case then it would be senseless to fix the cracks because the plaster is going to be falling apart faster than you can make the house look nice. Some places you could go over it with drywall, but if you can tear it out (which is one heck of a job) then you can up grade wiring and put in some changes here and there to put your touches on the house.
redmanblackdog is offline   Reply With Quote
The Following User Says Thank You to redmanblackdog For This Useful Post:
Old 03-06-2011, 04:20 PM   #8
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 906
Yep....
Sir MixAlot is online now   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
slight cracks between wall and ceiling deetu Painting 6 03-07-2009 04:53 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
