Recurring Drywall Crack? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-17-2008, 10:02 PM   #1
Rewards Points: 552
Recurring drywall crack?
I have a drywall seam crack that keeps reappearing and it's driving me batty. I've tried everything from spackle to elastic crack spray with no results. I suspect the best solution is to pull the old drywall tape and re-tape it. However, that solution seems rather drastic. Is there anything else that might work?
kcrossley2 is offline   Reply With Quote
Old 11-17-2008, 10:38 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by kcrossley2 View Post
...I suspect the best solution is to pull the old drywall tape and re-tape it.
Yes, you have it right. Read below.
No, absolutley no, this is not a drastic step. It is a necessary step for a proper drywall crack repair. Cracks cannot be repaired by simply coating with spackle.
You must apply tape, to the crack.
If you tape the crack, coat as needed, and sand, it should not re-crack. If the crack is an obvious "sheetrock seam", then you may also wish to install additional drywall screws to the area (secure it), before taping and coating.
Good Luck.
- Build Well -
Old 11-18-2008, 10:03 AM   #3
Drywall contractor
Rewards Points: 1,070
WB is absolutely correct. Where is the problem area?? Over a door or window? If so, likely it didn't get fastened properly. Often the hangers will just nail top and bottom on short header spans allowing movement when doors/windows are opened and closed....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Sanding drywall primer and a few crack repairs n0c7 Drywall & Plaster 4 06-09-2008 03:31 AM
Why do drywall joints crack in garages? Weelee929 General DIY Discussions 3 01-06-2006 08:30 AM
